Home > Technical > Wiring up some spots
Tiger
Wiring Diagram help.
Right I'm gonna wire my lights in.
I have
LED Light bar on the roof
Halogen Spots in the 'A' Bar
I Now have a proper LR '2nd' light switch
What I want is these as options
Only factory lights. (dip / main beam)
Factory + Spots only (coming on with the main beam)
Factory + LED Bar only (coming on with the main beam)
Factory + Spots + LED Bar (coming on with the main beam)
Do-able with a little bank of extra switches?
Post #266653 14th Sep 2013 3:17pm
Tiger
How's this?
Post #266678 14th Sep 2013 4:53pm
Tiger
Having a blonde moment and I can bin the top relay, no need for 3!
Doh!
Post #266681 14th Sep 2013 5:11pm
K9F
You also have three switches on the earth line for the relays or are you earthing all the relays through the same OEM dash switch? Yes you can bin the top relay and the two seperate earth switches by wiring both through the OEM dash switch. Why overcomplicate it? All or nothing isolation from main beam achieved through the single OEM dash switch. Less to go wrong.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #266724 14th Sep 2013 7:27pm
Tiger
Changed it to this
Post #266725 14th Sep 2013 7:30pm
K9F
But you don't link your 85 & 87 or you'll be putting your relay output to ground through the LED when you operate your auxillary switch.. Put the LED in series with your relay coil terminal 86. Thumbs Up
Post #266729 14th Sep 2013 7:42pm
Tiger
Fair point well made. Thumbs Up
Thank's for your help
Post #266763 14th Sep 2013 9:27pm
K9F
Thumbs Up
Welcome! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #266775 14th Sep 2013 10:13pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Sure you will already have thought of it, but just make sure you get the power ratings fully calculated for the lights first so you can select the correct cable / fuses / relays etc. 15A may not be sufficient depending on what lights you use. Some of the 40" LED bars can draw upto 20A on their own.
Good luck! Thumbs Up
Post #266779 14th Sep 2013 10:33pm
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
My only thought on this one is that with the LED in series, if it fails then so do your lights.
You could use switches that illuminate when selected, there's plenty of site sponsors that will sell you some. Carling switches etc.
Post #266789 15th Sep 2013 5:36am
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Which Defender and what switches are you using. TD5 dash switches are switched on the negative side. 2007 TD5 90 Hard Top
Post #266790 15th Sep 2013 5:40am
Tiger
How would I put these in then?
So I'd have the OE switch as the master cut off.
The two of the above switches that control the two circuits.
I would expect the LED on the switch to only light when the light is on.
ie:
Master OE Switch latched.
Rocker switched to on
Main Beam on
Help????
Wiring does my tiny brain in !!
Post #266852 15th Sep 2013 10:14am
Tiger
Assume the three connectors on the back will be:
Ground
Load
Supply
How does this work if wiring on the Ground as the OE switch dictates???
Help before I go to LR4x4 and get laughed at Big Cry
Post #266853 15th Sep 2013 10:18am
Landlord
This might help
And this thread covered something similar
http://www.defender2.net/forum/topic795.html 2007 TD5 90 Hard Top
Post #266860 15th Sep 2013 11:10am
Tiger
That diagram grounds 85 to 87 for the LED in the switch
K9F says not to do that, which seems to make sense.
Even more confused now!
Post #266861 15th Sep 2013 11:14am
