![]() | Home > Puma (Tdci) > DPF warning symbols on a 2.4TDCi |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
I took my instrument cluster apart this morning to investigate the apparently unused space below the fuel and temp guages, with a view to filling it with some form of useful information. Possibly Int/Ext temp or TPMS.
I found there are 2 LEDs and symbols for what appear to be DPF warning symbols. https://www.dropbox.com/s/fl6sis095mb3xlu/P1100097.jpg My Defender is a late 2010 model with the 2.4 engine, so is it safe to assume these lights will never come on, or should I make provisions for them on whatever I end up making? Cheers, Mark |
Is it possible to whip out the LEDs and use a multimeter across the terminals to check the resistive reading of any circuit? Alternatively just leave whatever is attached to the LEDs stored behind the dash and use the vacant space anyway. That way you can always revert back very easily should the need arise later.
They're not used on my 08 2.4 and I don't know if the LEDs are even there! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6328 ![]() ![]() ![]() |
I'm fairly confident to suggest NONE of the 2.4's have dpfs.
Are you sure Caterham? Could be your DPF is goosed and the lights are inoperative, you may have an issue that needs looking at utilising lots of your time?
![]() ![]() ![]() ![]() ![]() Just for clarity NO DPF or system monitoring functionality on a 2.4. ![]() Treat every day as if it is your last....one day you will be right!! |
![]() I knew something wasn't quite right .... having checked in my V5 mines actually a 2.402. perhaps mine does therefore have a dpf ![]() I need to get it to the dealers before warranty runs out for a couple of other things door lock and fuel breather pipe. I'll ask them to check out the dpf and warning lights. ![]() and I thought everything was going well ? ![]() |
![]() ![]() Glad to see you're happy of late, roses are blooming in your garden and you still have a sense of humour. Brilliant!!!! ![]() Treat every day as if it is your last....one day you will be right!! |
not only did I very nearly loose my sense of humour but my marbles too.
- one of the best was taking the regional LR technician, service manage and work shop manage out for a drive only to be told that the noises were normal / characteristic. that night I find heat shield bolts and heat shield brackets missing shortly before the gearbox failed ! sorry - OFF TOPIC. but as you say all good now. ![]() |
