Home > Maintenance & Modifications > Fog light recommendations
tobes01
My morning commute is getting darker again, and with it the fog is once more a problem. I've ordered a set of Wipac crystals etc for headlight replacements, and I'm chewing over the idea of some fogs mounted lower down - the TDCi doesn't do much off-roading, so vulnerability isn't an issue.
Any suggestions/recommendations for what to buy and where to mount please (90 TDCi with air-con)? I've looked at Mobilecentre but can't justify the £250+ I'd seem to need for LEDs...
Tobes ---
90 TDCi XS
1954 S1 2L Petrol
Previously: 90 2.5L Petrol, 110 300tdi, 1959 S2 2L Petrol, 127 200tdi Ambulance
Technical and DIY skills: NIL
Post #266279 13th Sep 2013 11:32am
I installed a pair of rigid Industry dually d2s .. from www.zenoverland.com, amber, 2600 lumens mounted in devon 4x4 hd bumper
Post #266290 13th Sep 2013 12:20pm
ericvv
Hella Comet 550 fogs. Cost not more than about $100 a pair. 55W halogen, perfect wide light spread and a classic look. Exist in white or yellow.
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #266295 13th Sep 2013 12:36pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
So you mounted a bull bar and steering protection.
Weird placing of those fog lights though...
Would 've been safer on top of the bumper or underneath the hirizontal part of the bull var (if possible).
Why that location?
Post #266330 13th Sep 2013 2:45pm
ericvv
It is the most efficient place for fog lights, i.e. low mounted and close to the sides of the truck. Look at 90% of the cars on the road with fog lights, and they will be in similar location as mine. Now, mine still are mounted pretty high off the ground, so unlikely to ever touch anything at all. You have to realize that this SVX is not an extreme off road truck, actually not an off road truck at all. Whistle
Auxiliary lamps at the underside of the soft A-bar are ok, actually perfect place for spots. That is really not the right place to put fog lights though, too high up, and too close to the center of the truck.
The steering protection came as standard with the SVX. You never actually own a Defender. You merely look after it for the next generation.
Post #266333 13th Sep 2013 3:15pm
tobes01
Thanks for the tips so far. Love the Dually lights, really don't love the price Sad (unless I've read it wrong!). Also reluctant to swap my bumper over, all that money (when I've earned it) is earmarked for a Blackvue or something similar. I think the under-the-bumper position is the way forward. ---
90 TDCi XS
1954 S1 2L Petrol
Post #266341 13th Sep 2013 3:32pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Hi Ericvv,
A resurrection if I may.
I've now got the Speaker headlights I see on your truck and I bought, some time ago, but not yet fitted the Hella fog lamps.
Do the Speakers render the fogs redundant or are they still worth putting on, in your view?
Thanks
Simon. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #300292 19th Jan 2014 3:10pm
ericvv
Simon, still worth putting on. While the Speakers give a nice wide light spread already, my Hella fogs simply give an extra coverage at an even much wider angle at both sides of the truck and this for the first 3 or 4 meters starting from the bumper. That is exactly what good fogs are supposed to do. On twisty roads, these fogs are still a great addition to light up the closeby sides of the road, especially handy in turns.
Keep us posted of how you like them in case you install them. Thumbs Up
Post #300298 19th Jan 2014 3:58pm
Macpaul
Most helpful reply Eric, thank you very much Thumbs Up
Post #300313 19th Jan 2014 4:57pm
