Home > Maintenance & Modifications > What To use and how to dinitrol
bear100
This has probably been asked a few times, can't find much on the search.
I want to dinitrol my 110, I have never done this before and not sure where to start.
Which products do I use? ML3125 inside the box section and 4941 on the on the external?
How much do I do? Just the chasis and axels? Or every thing except exhaust?
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #263800 4th Sep 2013 7:33pm
Under body was on any steel surfaces so axles, springs (if need be) chassis and so on. You can do floor pans underneath too as I did but that is only for satisfaction really that it is ALL done. No Guts, No Glory.
Post #263804 4th Sep 2013 7:39pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I bought this kit from rejel
http://www.rejel.com/rejel-store/categoryi.../9405.aspx
I found there was 1 can too many of the cavity wax and one too few of the underbody stuff. However, I did do all the underside of my 110 including springs and floor panels and inner arches front and rear (galvanised arches rather than the plastic ones fitted these days.
http://www.defender2.net/forum/topic20716.html
Have fun
Post #263816 4th Sep 2013 8:03pm
Merlin
Once done, how often should it be renewed? The supplier says 6 months to 2 years, but they would wouldn't they? So what's the practical life?
Merlin
Post #263977 5th Sep 2013 3:18pm
Sockpuppet
Once every two years would probably work for me.
Post #263982 5th Sep 2013 3:34pm
I would say one year for a top up but more major after 2 years. To be honest unless you do serious off-roading or especially wading then I think it will be fie for quite a long while. It's the initial application that's the most important IMO anything else is adding more to it. No Guts, No Glory.
Post #263983 5th Sep 2013 3:37pm
jimbob7
To start with, spend 6 months jet washing the chassis,this is how long I have been cleaning mine and this morning I found another clump of dried mud Confused .I'm pretty sure it's clean now...it better be, as I painted all the x-members,outriggers and most of the chassis in June.
Personally, I'm only going to properly Dinitrol (aerosols) the inside of the chassis and x-members,with only a very,very light coating on the outside,as I like to jet wash periodically and will Dinitrol the outside again before next winter.
Post #263988 5th Sep 2013 3:46pm
I cleaned mine too completely by hand and to the rear had to internally also. Shocked A real painstaking job though to get right AND find all the dirt and rubbish lingering. It is possible though. Not easy with no ramps or anything for that matter. No Guts, No Glory.
Post #263993 5th Sep 2013 3:59pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Merlin
Proper coat of 3125 and 4941 on top and you won't have to reapply for 3-4 years even with hard off road use. Just touch up with a can of 4941 if you get knock etc. and on main wear points.
Steve
Post #264120 5th Sep 2013 9:07pm
