Home > In Car Electronics > Sub wiring routes |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20441 |
Earth on a suitable bolt that has a good earth too it, substantial if possible. I used one along the lip on the cab side of the bulkhead on the floor.
Power I took out of the battery box out along with the others through some protective conduit and through the plate under the cubby (Using a cable gland) [A grommet would equally work] From these route where ever you like. For your cables from the HU i.e. RCA & remote I would run along the transmission tunnel area under the carpet or matting. Try and keep you signals cables as far away from power cables if possible and where practical to avoid possible problems. IF the have to cross at right angles is best but don't worry too much about it. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
3rd Sep 2013 9:50pm |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 |
i only have a small underseat one on the back of the cubby and put my +ve and -ve behind the passenger side and into a grommit for the heated seats to the battery, The signal and L + R i put under the cubby and then under the carpets and up to the head unit. The rmote sits to the right of the steering column and took the same routes as the head unit and extended across. William
5th Sep 2013 8:47am |
I fitted mine using an umbillical type cable following the same route and process as Custom90steve (probably the identical glands with the same batch number too perhaps?) so dependant on what I'm carrying the sub can be moved about the rear of the truck out of harms way if need be.
If I am going to be rendered incapacitated by my pedal lock in the event of a crash the sub can have a second go! (Forum joke!). If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 5th Sep 2013 11:50am. Edited 3 times in total |
5th Sep 2013 11:20am |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 |
Bear,
Killer and myself have different Sub's installed and I dare say through different methods and routes. Both vehicles will be at Peterborough so maybe pop over with a Camera and you can have a look/ take pictures We will both be up there by tomorrow evening. Also opposite is Matt (FCX) with the frankly pornographic orange interior 130 which I think I recall has a sub in there and can have a look (he left the doors open for people to look in at Billing) Hope this helps with a solution to your query Steve =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
5th Sep 2013 11:46am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Thanks Lish
Yes, you are very welcome to come and have a look at the FCX130. We ran ALL cables externally through various lengths of convoluted tubing with gland fittings at each end, happy to show you As Steve has said, we ran audio leads in different tubes to power cables to eliminate 'noise' |
5th Sep 2013 12:19pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1917 |
Cheers guys I will certainly pop over and have a look
2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
5th Sep 2013 8:30pm |
