Home > Maintenance & Modifications > Replacing glass in pick-up
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I've recently broken one of the glass panels in the rear sliding window of my old pick-up, I've got the glass panel ready to put back in, before I start to take everything off and probably do something unnecessary, is there an easy way of doing it?!!
It's the panel at the back of the cab, one panel is fixed, the other slides. It just needs to go into the frame somehow.
Post #263239 2nd Sep 2013 8:56pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
No easy way, sorry. Remove the two side trims and the lower if you have them then unscrew the small metal strip at the top. By rights you ought to take the head lining out too but I found the metal strip covers what little bit of damage you do. Next drill out all 20 rivets. The frame is also bonded with double sided pads. From the back gentlyprise out the frame. It Iis in two halves which are held by two fish plates on the short sides. Take it apart and work all the old rivets out of the channel so they don't rattle. Also take the time to get new felt for the runners keeps the draughts out. Assembly is the reverse order. Hth. Rhubarb and custard let fly with their secret weapon.
Post #263299 3rd Sep 2013 4:35am
Lambley
Thanks for the reply Lambert, to be honest I'm about to recover the headlining and side panels anyway so I'll do it all in one go. Sounds like a long job, that'll teach me! Cheers
Post #263300 3rd Sep 2013 4:43am
lambert.the.farmer
Tbh I had mine done in a couple of hours working it out as I went. Not that bad a job really. Rhubarb and custard let fly with their secret weapon.
Post #263307 3rd Sep 2013 6:19am
Lambley
Thanks Lambert, I did the window today, after taking the roof lining etc out, to my surprise (and delight) I discovered that instead of rivets holding the window in, it was screws, I thanked my lucky stars and did it in about an hour.
Cheers for the help
Post #263835 4th Sep 2013 8:43pm
