Home > Maintenance & Modifications > Replacing glass in pick-up |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
No easy way, sorry. Remove the two side trims and the lower if you have them then unscrew the small metal strip at the top. By rights you ought to take the head lining out too but I found the metal strip covers what little bit of damage you do. Next drill out all 20 rivets. The frame is also bonded with double sided pads. From the back gentlyprise out the frame. It Iis in two halves which are held by two fish plates on the short sides. Take it apart and work all the old rivets out of the channel so they don't rattle. Also take the time to get new felt for the runners keeps the draughts out. Assembly is the reverse order. Hth. Rhubarb and custard let fly with their secret weapon.
3rd Sep 2013 4:35am |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Thanks for the reply Lambert, to be honest I'm about to recover the headlining and side panels anyway so I'll do it all in one go. Sounds like a long job, that'll teach me! Cheers
3rd Sep 2013 4:43am |
Tbh I had mine done in a couple of hours working it out as I went. Not that bad a job really. Rhubarb and custard let fly with their secret weapon.
3rd Sep 2013 6:19am |
Thanks Lambert, I did the window today, after taking the roof lining etc out, to my surprise (and delight) I discovered that instead of rivets holding the window in, it was screws, I thanked my lucky stars and did it in about an hour.
Cheers for the help |
4th Sep 2013 8:43pm |
