![]() | Home > Maintenance & Modifications > Aerosol vs compressor Dinitrol application (Lancashire) |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
IMHO you will get better coverage and a thicker coating with compressor application than a DIY flick can application.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
I've done mine with aerosol cans. Just depends simply on how you use it and how much you put on.
I'm personally very pleased and there isn't really a difference in price. ![]() Click image to enlarge WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203 ![]() ![]() ![]() |
You won't believe this-I'm just from starting mine. Spoke to Peter at Rejel, great guy
![]() Contact Mick Gresty, Rust Master. 07748274966. Based in Manchester. I am no way guaranteeing his work. I do not know him, but I will say that Peter is a honourable sort of chap and worth a phone call for advice ![]() ![]() ![]() |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 ![]() ![]() ![]() |
I did mine with aerosols, no problems and happy with the results. I also keep going back now and then to squirt wherever I have just moved some bolts about or changed something, for which aerosols is probably less hassle.
good luck, it's a little messy however you do it.Cheers, John. 2.2 90 XS 88" Series One Old Norton ![]() Minerva |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1979 ![]() ![]() ![]() |
You have always got the option of hiring a compresser from a high street hire shop would probably cost no more than £30 for a weekend
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Zag and i are doing my 130 on Saturday so I will get some pictures taken if I'm not covered in Dinitrol.
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
!!!!!! SGH where is my invite
Potter Member Since: 21 Aug 2013 Location: United Kingdom Posts: 40 ![]() ![]() ![]() |
Cheers folks.
I'll give Rejel a call and see what they say about the aerosol application. |
I'll drop mine over to do then ![]() |
