Home > Maintenance & Modifications > Squeaky clutch?.....Easy mod!
Page 1 of 3 123>
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Do not know whether this mod has been discussed before but here goes:
Really a 5 minute job.
Look in the engine bay to the area below the header tank. That black box is the clutch box. Now see the "bush" on the right side of the box (circled in red). That bush is the culprit. And best of all is that it is threaded already!
Some models do not have any silicone there but some models do???? If there is silicone (you'll easily feel it) try your bestest to get all of it of/out the hole.
Now make sure you have a grease nipple with a 6mm thread. Like this:
Get out your 10mm flat spanner and thread that grease nipple into the threaded hole. When your done, grap the grease gun and give it about two squirts Embarassed
You can/should also open the "lid" of the box by removing the 6 screws and for good measure squirt some WD40 in there as well.
Within a few miles of city driving you should have a sqaukless clutch. :thumbsup:
Post #263457 3rd Sep 2013 6:19pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Nice mod i had the squeeky clutch pedal on my old 300 Tdi never did sort it,wish i had known about this then it used to drive me nuts. 2005 Td5 90 XS
Steve
Post #263482 3rd Sep 2013 7:35pm
patclan
Australia 2010 Defender 110 Puma 2.4 SW Santorini Black
I have been suffering from squeaky clucth syndrome for a year, I have sprayed every possible lubricant up behind the pedal and found only temporary relief. I will be trying this as soon as I get the nipple..
Thanks heaps for that.
Post #263874 5th Sep 2013 3:39am
Naks
Thanks boet!
How is the 110 coming along? --
Post #263911 5th Sep 2013 9:51am
Regard
Hi Naks
I just love that 110 RAW/X-tex. But I do miss the 90.
Just PITA to start from scratch with all the mods....but I guess it is half the fun Whistle
Must just mention that this was a plan made by a local forum member on 4x4community.co.za
Post #263925 5th Sep 2013 10:35am
Vanderbult
Netherlands 2011 Defender 90 Puma 2.4 SW Santorini Black
Re: Squeaky clutch?.....Easy mod!
i have a 90 "2011 model and mine has the silicon in the whole, how do i get it out?
Post #469024 3rd Nov 2015 1:44pm
Vanderbult
next to some silicon there is also some sort of bush or small bolt in the thread, do i have to remove that before fitting a grease nipple?
Post #469048 3rd Nov 2015 2:31pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
nice tip, thanks! Bow down My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #689537 28th Feb 2018 11:40am
mick
I’ve done this but it’s not working at the moment Rolling Eyes
Post #695735 23rd Mar 2018 7:43pm
williamthedog
Cool tip Thumbs Up
Post #695749 23rd Mar 2018 8:48pm
ajps72
2001 Defender 110 Td5 SW Chawton White
It didn´t work for me either, so I opened the top cover, (philips screws) and grease the "pulling joint" (you will see). I used Moliketo grease.
And its working ok without squeaky Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #696051 25th Mar 2018 3:32pm
mick
It’s in for service tomorrow they said they would do it. Thumbs Up
Post #696102 25th Mar 2018 8:13pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
That looks good that, Ill have to pick up some nipples Laughing Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #766634 3rd Apr 2019 12:21pm
Is this threaded hole on the Puma as well? Specifically the 2.4. I thought I saw similar when looking at it the other day TheThunderRolls🇬🇧🇺🇸
Post #766676 3rd Apr 2019 4:47pm
Zed
It was on mine. Did the mod and it worked a treat.
Post #767331 7th Apr 2019 7:17am
Page 1 of 3 123>
