Home > Maintenance & Modifications > Squeaky clutch?.....Easy mod!
Page 2 of 3 <123>
Mo Murphy
I did it years ago when this thread was started. Hasn't squeaked since 😊🖒
50 Shades of Pennine Grey
Post #767351 7th Apr 2019 9:04am
I’ll have to have a look again shortly. Thank you. WeWillWin🇬🇧🇺🇸
Post #767385 7th Apr 2019 11:56am
newton-tony
United Kingdom 2014 Defender 110 Puma 2.2 USW Firenze Red
This is on my list of jobs and fingers crossed!
Bow down
Post #767461 7th Apr 2019 6:59pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Question. Tried to do this mod Today (whilst waiting for the paint to dry), but can i screw in the nipple on both sides?
Left is for my the easier side but could’t screw it in. At long last i succeded to take a Photo of the left side. Any ideas?
 a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #771502 4th May 2019 1:25pm
hank
You can or can't screw the nipple?
I am not sure what you mean when you say both sides? For me there was just one place where the nipple could/would go...
 > 110 XS Double Cab
Post #771511 4th May 2019 3:20pm
Tdi4
In my perspective this is the right side. But i drive a lhd car and the right side of the clutch box is hard to reach so i would like to screw in the nipple on the left side of the clutch box a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #771513 4th May 2019 3:25pm
hank
Ah I understand, but unfortunately I can't offer any additional help on the problem. Mine screwed in very easily. Good luck! > 110 XS Double Cab
Post #771514 4th May 2019 3:39pm
PCM
Did this mod last week and for the first time in a long time have a squeak free clutch. Also fitted a power spring. Fiddly, but well worth it.
Thumbs Up
Post #771517 4th May 2019 4:03pm
Tdi4
Not sorted yet. Does anyone have a spare Black clutch box of which they can take a Photo on both sides?
Or has anyone done this mod on a lhd car?? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #771522 4th May 2019 4:50pm
hank
Post #771525 4th May 2019 5:13pm
Tdi4
The axle (part nr 272712), at least how i look at it, isn’t symetrical. My assumption now that this axle can be switched but you need to get out this box.
Just a long shot Laughing has anyone done this?
Ps thnx hank a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #771528 4th May 2019 5:36pm
Hank - How did you manage to fit the angled grease nipple? On mind the thread was much smaller than that so only could fit the smaller grease nipple at 90 dregrees ofset from the side of the clutch box wall.
Did you enlarge the threads? Or were they present already.
If the latter much have different to mine. WeWillWin🇬🇧🇺🇸
Post #771530 4th May 2019 5:44pm
hank
It didn't feel like a particularly positive thread engagement when I screwed the grease nipple in. Access is poor so I could not inspect but it it felt like more of an interference fit rather than the hole being threaded
I used one of these, m6x1 90 degree https://www.ebay.co.uk/itm/121996885345
TDi4 - I agree from your picture it looks like the pivot axle is the 'wrong way round' on your LHD. Looks like you have access to the larger locking pin end rather than the smaller end. Like you say you would need to remove and refit in the opposite direction
 > 110 XS Double Cab
Post #771541 4th May 2019 7:08pm
Oldowner
Earlier pre td5 defenders don’t have a predrilled hole in the pivot pin.
I have always found that squeaking is more likely to come from the top pivot which is unbushed wheras the pedal pivot has bronze bushes, but adding the grease nipple is no bad thing.
Post #771584 5th May 2019 6:40am
Ianh
Regarding the grease nipple being a metric 6mm.
I was reading another topic on this subject https://www.defender2.net/forum/topic45191...p;start=30
Blackwolf highlighted the following, which strongly indicates it’s actually a 1/4" UNF grease nipple.
blackwolf wrote:
nosnibod wrote:
I've tried everything everyone here has suggested. None of it worked.
However what did work was greasing the main pedal pivot - and no it doesn't mean taking everything apart.
If you feel down the inside of the pedal box - from inside the engine bay, you will feel the end of the shaft that the pedal rotates on. It's hollow, and seems to have grease ports inside it out to the bearing surface.
The end of that shaft is in fact threaded for a grease nipple but LR - in their wisdom - just bung some sealant in there instead.
If you prise the sealant out, put a grease nipple in, you can inject grease into the pedal pivot.
It's been covered on here before:-
http://www.defender2.net/forum/post469048.html
And here for more photos:-
http://www.4x4community.co.za/forum/showth...utch-pedal
In the linked thread there is a long discussion about the size of the nipple (ie the thread in the end of the shaft), the general consensus being (a) that it is 6mm, and (b) that it is the same as the thread in the grease nipple holes in the propshafts. Clearly these two conclusions are mutually exclusive since the thread in the propshaft holes is 1/4" UNF and not 6mm. it is likely that you can force a 6mm nipple into a 1/4" UNF hole since a 6mm coarse thread has a 1mm pitch (conveniently therefore 25.4 tpi) and 1/4 UNF is 28tpi.
I've done some digging into the origins of the shaft, and the Puma clutch pedal pivot shaft, p/n 272712 actually first appeared with introduction pendant-mounted pedals on the SII in 1958/9 and has been the same part (and the same part number) ever since. In Series days, the hole in the end of the shaft was plugged with a hex head setscrew, p/n 255202, which has had various descriptions in the parts books over the years, the most descriptive being "Oil plug for pedal shaft". As far as I can determine, 255202 is a 1/4" UNF x 3/8" long hex setscrew. I suspect that it is only in recent times that the dreaded bean counters insisted that the screw was replaced with a blob of sealant.
I do find it amusing that long after the owner's manual stopped telling the owner to remove the retaining screw, fit a nipple, inject oil, remove the nipple, and replace the retaining screw, JLR was STILL buying shafts which were fully machined to support proper lubrication! There are at least three machining operations needed on the shaft which are completely redundant, although handy for those of use with squeaky pedals.
Post #1027661 11th Mar 2024 7:30pm
Page 2 of 3 <123>
