Home > Puma (Tdci) > Friction modifier in MT82 gearbox ? |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
This morning I (reluctantly )cut a small square out of my LR mat to enable the clutch pedal to travel fully. I stuck a piece of thinner rubber on the back to stop the muck getting through and then forgot about it.
Later the missus came back from the shops and remarked how the gearbox appears to be 'loosening up nicely' as it was going into gear so much easier. So its definately not a placebo situation ! I wonder if such a simple thing is contributing to transmission issues of which there seem to be many ? How many owners have genuine LR mats which although expensive and excellent quality are possibly too thick to allow a proper gearchange ? I don't know - maybe its not relevant but it just might be worth looking at |
4th Sep 2011 8:35pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2645 |
Hmm, I'll try as well and report tomorrow! -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
5th Sep 2011 7:08am |
Removing the rubber mat made no difference to the gearchange clunks in my truck --
8th Sep 2011 8:40am |
I have used this in my Audi A2 and VW Beetle and I have to admit, embarrassingly, that it seems to work... |
17th Sep 2011 2:44pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
Where do you buy this wonder oil additive in the UK?
Merlin |
2nd Sep 2013 1:20pm |
Sorry - bought mine from Italy Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
2nd Sep 2013 3:01pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
I would have thought that if you have to push the clutch down that far it must be nearly worn out. The biting point should be much higher up, surely..? (Disclaimer: I drive a TD5, so no idea how this compares to a Puma drivetrain) cheers simon |
2nd Sep 2013 4:00pm |
Biting point is higher on mine too - on a Puma. I have carpets and mats and still have loads of travel Tell someone you love them today because life is short.
2nd Sep 2013 4:20pm |
