Home > Puma (Tdci) > Head Light Leveling |
mhill Member Since: 25 Jan 2010 Location: Tendring, Essex Posts: 46 |
Any ideas why a 2009 XS Doubble Cab wouldn't have a head light levelling switch?
7th Mar 2010 10:18pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Caus its built by brummies
7th Mar 2010 10:28pm |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 808 |
I thought some 110s still had a Boge self-leveller fitted? XSs?
Have a look on the rear axle? |
8th Mar 2010 10:55am |
Phoned up the local stealer earlier and apparently it was specked by the original owner without head lamp levelling, could this be the case?
8th Mar 2010 9:56pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Doesn't come with the adjustable lights. Probably because it comes with the HD rear suspension which means that if you have anything less than a ton in the tub and a full load the ligts won't need adjusting. Glyn |
8th Mar 2010 10:14pm |
So what about when i regularly have the full 3500kg behind on the trailer? |
8th Mar 2010 10:22pm |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 |
what are the 'dim dip' lights, obviously not high and low beam...not sure really... |
8th Mar 2010 10:26pm |
With that remembr that only 150Kg or so is pushing down on the tow ball, the 3500Kg is on the trailers' wheels so shouldn't alter the angle of the vehicle much if any. Glyn |
