Home > Puma (Tdci) > Head Light Leveling
mhill
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Bonatti Grey
Head Light Leveling
Any ideas why a 2009 XS Doubble Cab wouldn't have a head light levelling switch?
Post #26141 7th Mar 2010 10:18pm
Caus its built by brummies
Post #26151 7th Mar 2010 10:28pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I thought some 110s still had a Boge self-leveller fitted? XSs?
Have a look on the rear axle?
Post #26197 8th Mar 2010 10:55am
Grockle
because it a commercial and has dim dip headlights 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #26229 8th Mar 2010 3:57pm
mhill
Phoned up the local stealer earlier and apparently it was specked by the original owner without head lamp levelling, could this be the case?
Post #26294 8th Mar 2010 9:56pm
Glynparry25
Doesn't come with the adjustable lights. Probably because it comes with the HD rear suspension which means that if you have anything less than a ton in the tub and a full load the ligts won't need adjusting.
Glyn Sheep
Post #26295 8th Mar 2010 10:14pm
mhill
Glyn Sheep
So what about when i regularly have the full 3500kg behind on the trailer?
Post #26297 8th Mar 2010 10:22pm
ti-fat-man
United Kingdom 2011 Defender 110 Puma 2.4 USW Alpine White
what are the 'dim dip' lights, obviously not high and low beam...not sure really... Embarassed
Post #26300 8th Mar 2010 10:26pm
Glynparry25
With that remembr that only 150Kg or so is pushing down on the tow ball, the 3500Kg is on the trailers' wheels so shouldn't alter the angle of the vehicle much if any.
Glyn Sheep
Post #26301 8th Mar 2010 10:26pm
