Home > Td5 > ABS extension leads
stevetd5
Australia 2002 Defender 110 Td5 SW Alpine White
ABS extension leads
Hi all, I have a 2" lift and am aware that there are extended ABS cables available so there is less chance of damage. Does anyone have a supplier as I have miss placed a contact I had (American co who was apparently an OE supplier). Thanks
Post #262395 30th Aug 2013 1:03pm
K9F
The ABS cables are only single-core. Any decent electrician should be able to extend them for you and make them environmentally sealed with the correct tooling and crimps in about 30 minutes toil. I repaired mine......
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #262438 30th Aug 2013 5:56pm
stevetd5
Thanks, I should have taken a closer look!! I will get onto them asap.Steve
Post #262615 31st Aug 2013 12:04pm
stevetd5
abs leads
Sorry about the multiple listing! I have found a supplier for a kit to replace abs sensor leads but its listed to suit a disco 2. Does anyone know if these are the same as the defender ones? thanks
Post #263669 4th Sep 2013 11:15am
