ABS extension leads
Hi all, I have a 2" lift and am aware that there are extended ABS cables available so there is less chance of damage. Does anyone have a supplier as I have miss placed a contact I had (American co who was apparently an OE supplier). Thanks
30th Aug 2013 1:03pm
K9F
The ABS cables are only single-core. Any decent electrician should be able to extend them for you and make them environmentally sealed with the correct tooling and crimps in about 30 minutes toil. I repaired mine......
Click image to enlargeIf you go through life with your head in the sand....all people will see is an ar5e!!
30th Aug 2013 5:56pm
stevetd5
Thanks, I should have taken a closer look!! I will get onto them asap.Steve
31st Aug 2013 12:04pm
stevetd5
abs leads
Sorry about the multiple listing! I have found a supplier for a kit to replace abs sensor leads but its listed to suit a disco 2. Does anyone know if these are the same as the defender ones? thanks
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
