Home > Off Topic > Landrover related job wanted |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
I think the above posts define networking. Good luck to both of you. BM52 |
29th Aug 2013 3:46pm |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 |
Although moving to Germany would be quite a thing, my knowledge of the language is a little limited (only enough to get by) and my mechanical skills are also limited an home-taught.
I am supposed to be at least moving onto a regular shift soon which will be mornings, so that will free up evenings for taking on new skills, I'll probably have a go at welding and mechanicing if only to reduce money being spent on the Landrovers... 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
29th Aug 2013 10:42pm |
I shan't comment regards LRE, but yeah off-road tuition would be a possibility, I actually had one of our drivers at work ask me why i wasn't doing HGV instruction...
Part time work would be an issue though (I can't do with all this "zero hours contract" garbage) as we are planning on having some babies soon enough... 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
30th Aug 2013 9:13am |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 |
This suprises me, having met you I would have thought you would be ideal? Maybe Ian stuck the boot in so he didnt lose you |
30th Aug 2013 11:41am |
