Home > Puma (Tdci) > could REALLY use some help. Fuel, filters, power problems
Cheshire110
So i have a '10 2.4 tdci 110 as many will know.
We get our diesel from a tank at our house, and after a delivery of fuel into tank at house cr*p was stirred up and got into my tank and also my dads. (begin problems.....)
Dad has a 4.2 land cruiser amazon (AUTO) and we both had similar (isn) problems.
- lack of power at anything over tick over
- generally rough sounding engine
i (not dad) had some extra problems:
- stalling when in neutral at tick over (guess dads v8 diesel has enough momentum & cylinders to ride it out)
- very lumpy delivery of power (i shall elaborate: when you put into gear it runs well with normal levels of torque at tick over, but when you put foot down have NO power - can barely increase speed at all. only way to accelerate is to change up a gear and let anti-stall do its thing (only works up to about 25))
- every so often, full power comes back and i remember that through the gears my car should actually pull well!
What we've done:
we have both changed fuel filters twice and dads is sorted, but mine is still (intermittently) struggling but its very bad at least 50/60% of the time. Its as though the engine is going into limp mode.
Fuel is now clean, brand new (+primed) fuel filter fitted. (the old filter was fitted for 3-4 days and when i changed it, the contents was like gravy!)
could;
a) i be fitting the filters wrong? air in system? they seem ok and dont leak but maybe thats the first thing to check?
b) the engine be going into 'limp mode' because it THINKS theres still a problem?
c) there be some other problem?
any advice would be MUCH appreciated! Cheers, David
Post #262246 29th Aug 2013 8:55pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Change the fuel filter have you used a genuine one ? As we had problems with a britpart one coming loose and not seating properly
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #262265 29th Aug 2013 9:33pm
Cheshire110
The filter is a fairly expensive (�25) MANN filters part. Seems to fit well. Cheers, David
Post #262274 29th Aug 2013 9:45pm
big steve
Yes but there is a lot to be said about genuine parts that being one of them Thumbs Up 2015 2.2 tdci hardtop xs
Post #262275 29th Aug 2013 9:46pm
GUM97
Make sure you're using genuine filters. Have you tried flushing the fuel system? Drained your fuel tank to remove any sediment?
Also, what exactly was the contaminant that was stirred up? Just general silt, or something more serious like metal coming from the delivery vehicle/hose? An engine to TDi for!
Post #262276 29th Aug 2013 9:47pm
Cheshire110
I could be wrong but I don't feel like it's the fuel filter anymore.
The 'contaminant' was just mucky sludge from the bottom of the tank.
Tank now has a filter on it, have emptied and re-filled tank twice and put some REDEX injector cleaner in.
It's as though the car thinks it has a problem and is going into limp mode.. But I'm not sure? What is limp mode like in a tdci defender? As described above? Cheers, David
Post #262278 29th Aug 2013 9:52pm
GUM97
I've no experience with limp mode on the 2.4's to be honest, but if it is that and it can't be self diagnosed, then it may be a trip to the stealers for a plug in! An engine to TDi for!
Post #262281 29th Aug 2013 9:55pm
excossack
Could it be contaminated diesel that got delivered? Would it be worth putting a sample into a clear glass beaker and see how it settles over night? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #262282 29th Aug 2013 10:04pm
spudfan
Ireland
I've been using an 1100 litre storage tank for road diesel in the shed for years and I never had any problems.
My 2008 Puma has a non Land Rover fuel filter fitted, it is a Stenadyne (someone said on here that they make the Land Rover filter). My diesel storage tank has been filled many times and I never had any bother with sediment. It is not fitted with any type of inline filtration. The diesel comes straight from the tank through the hose into the Land Rover. If you get a fill up to the tank let it settle for a while before filling your Land Rover from it. Do you have a slight back slope on the tank? As the tank outlet is a well above the bottom of the tank, sediment should not be a problem.
Get your supplier to drain your tank for you. He will back suck the diesel, and if sediment is present that will be sucked up too. You will be left with a totally clean tank. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #262289 29th Aug 2013 10:24pm
Cheshire110
We know there was cr*p in the tank, it's not been cleaned for 10+ years! Getting cleaned out ASAP, fuel is now fine as our RR and land cruiser are both running smoothly and have been getting fuel from the same place.
I'll drop into guy salmon tomorrow and see if they can advise, just didn't know if anyone had experienced similar symptoms. Cheers, David
Post #262297 29th Aug 2013 10:40pm
spudfan
Ireland
I've been using my diesel storage tank for over 10 years too. It has never been drained or cleaned either. A qiuck check with a flash light when the level is low is my only monitoring!
I suppose if you are O.K. now you could get the tank drained and cleaned at 5 yearly intervals for peace of mind. As I never had bother in all these years and have no filter on mine, you must have received more than one bad batch of diesel. Next time you get a fillup look into it using a flashlamp after it has settled. Maybe your supplier does not change the filters on the truck as often as he should. 1982 88" 2.25 diesel
Post #262307 29th Aug 2013 10:55pm
Cheshire110
Hmmm...
Land rover technician thinks fuel line needs bleeding. Quite common apparently since the tdci has no auto-bleed feature (great F'ing idea that was you idiots at ford)
Tried to pump fuel through lines and out at the engine end before with a hand pump like on outboard engines, to no avail.
Starting to doubt everything now, very frustrated. And I know that a main dealer will insist on a ridiculous (and expensive) list of things to be changed/replaced.
Why can't there just be a hand pump like in EVERY SINGLE OTHER CAR EVER which doesn't auto bleed!?
Really need someone who knows what they're doing, which seems to be very uncommon nowadays. Useless design combined with ineptitude at dealerships... Very frustrated as I sit here.
Car will run but pours out smoke and stalls all the time. Cheers, David
Post #262406 30th Aug 2013 3:49pm
big steve
im still pretty certain its the fuel filter as my bro in laws car had the exact symptons when he ran it out of diesel bought a brand new genuine filter filled it with diesel red ex injecor cleaner and its beene fine since
bearing miind the previouse filter was only 2 moths old as the britpar one fell off he was sick as a dog as the 2 genuine filters wernt cheap
steve 2015 2.2 tdci hardtop xs
Post #262407 30th Aug 2013 4:02pm
Cheshire110
I'm afraid I'm 99.9999% sure it's not he filter, have put 2 different brand new filters in.
Engine runs ok at first, then deteriorates. When check filter after, it's usually only half full or so.
It's as though the engine is unable to pull new fuel into and through the filter. Cheers, David
Post #262409 30th Aug 2013 4:12pm
smb
That sounds more like it is sucking air in from somewhere. Are you sure it is seated correctly and tightened up. Have you made sure there is no contaminant on the seal surfaces. I had the same problem years ago so installed two fuel filters and bowls on the storage tank. Never had the problem since.
Post #262423 30th Aug 2013 5:48pm
