Home > Puma (Tdci) > could REALLY use some help. Fuel, filters, power problems
Page 2 of 2 <12
Dieselhead
Now,
When I went to the aid of a mate whos puma had died at the side of the road it was because I had fitted a brit part fuel filter.
That sucked air cause it did not seat like proper ones should
I ended up putting his old filter back on. Now how the hell do I bleed this thing at the side of the road Shocked
I ended up using my oil/fuild extractor. I pulled the pipe off the fuel rail & suffed the extractor on there with the aid of a rubber glove to form an air tight seal
Pulled through a few litres & reconected to the fuel rail. Cranked over a few times & away it went Surprised
Maybe you should do the same sort of thing???
Hope this helps Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #262732 31st Aug 2013 7:42pm
Cheshire110
Yeah I think that might be the next step
I fitted a outboard motor type primer bulb inline which I was trying to use to prime the system.
Will get a gen LR filter, check all pipe work for blockages, fill with fuel and try again with the connector off.
Strange because my replacement filters were expensive MANN filters parts! Cheers, David
Post #262743 31st Aug 2013 8:03pm
Cheshire110
well ive had very little luck so far.
Changed fuel filters twice (most recently to gen LR part just in case), had lots of injector cleaner in, emptied and refilled tank, bled(isn?) system to no avail. even had filter HOUSING changed in case of blockage etc.
this was the end result of todays work:
AA man was lovely, and the truck was a fair old piece of kit!
car's been recovered to the garage, hopefully will have some news tomorrow.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers, David
Post #263865 4th Sep 2013 10:30pm
Cheshire110
Update on this saga.
Tank, lift pump, fuel line, filter housing, filter all either cleaned, replaced or refurbished at Guy Salmon's expense (hooray!)
Bad news: no change. Almost certainly either high pressure pump which should go through warranty, but can't get part until next Friday.
Scuppers my NWLRC weekend, but looking into hiring a vehicle for that! (Maybe a discovery 4 lol!)
Frustrating...
I didn't even know the puma had a lift pump! Cheers, David
Post #265612 11th Sep 2013 12:42pm
Shep
2010 Defender 110 Puma 2.4 USW Orkney Grey
Sorry i don't know the engine at all, but if it were an old school diesel i'd be looking for the injector pump pre filter gauze, normally on the injector pump inlet, these used to be incredibly fine and would block if water got that far.
As i said i don't know the engine it might not have one Question A man with no boat is a prisoner
Post #265680 11th Sep 2013 3:41pm
Cheshire110
could be, im not sure either.
TBH im just going to let guy salmon and the warranty people do their stuff!
been a very frustrating episode, but its resulted in me getting to go off road for the weekend in a discovery 4 (yay) Cheers, David
Post #265683 11th Sep 2013 3:46pm
Shep
New pumps appear to be eye wateringly expensive, i hope you didn't tell them you put dirty fuel in it! A man with no boat is a prisoner
Post #265684 11th Sep 2013 3:48pm
Cheshire110
575+VAT+Labour! Yes they are expensive indeed!
will wait and see what warranty people say! Cheers, David
Post #265686 11th Sep 2013 3:50pm
Cheshire110
RESOLVED!
details on my thread in 'MY DEFENDER' but the fuel pump was on the way out and eventually failed.
replaced now after near 2wk wait for part Cheers, David
Post #269585 26th Sep 2013 2:31pm
Page 2 of 2 <12
