Home > Technical > Wet Clutch pedal
ttuck3r
Scotland 1999 Defender 90 Td5 HT Caledonian Blue
Wet Clutch pedal
My Next door neighbor called me over to show me an oily substance on her shoes and where she thinks it came from, its a 26 year old defender and the clutch pedal is drenched with a fine clear oily substance, but i could not see where it was coming from, i think this weekend i will give it a clean up and check fluid levels..
Post #261973 28th Aug 2013 8:03pm
landy andy
That will be the clutch cylinder. Best to change both, slave and master, as they have both done the same amount of work. The fluid will be brake fluid, so be cautious where it ends up
Andy
Post #261975 28th Aug 2013 8:05pm
excossack
Knackered clutch master cylinder prehaps? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #261976 28th Aug 2013 8:05pm
ttuck3r
ive been told its Dot 4 dripping there which is not good on paint work...
Post #261981 28th Aug 2013 8:11pm
Happyoldgit
Yep, clutch master cylinder seals knackered. Steve.
http://forums.lr4x4.com
Post #261983 28th Aug 2013 8:14pm
ttuck3r
So am i right in saying this can be replaced (the seal) instead of the whole master cylinder.
Post #261989 28th Aug 2013 8:34pm
Martin
Site Admin
For the faff factor alone I would just change the master cylinder for a good quality one.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #261991 28th Aug 2013 8:38pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
You can indeed replace just the seal but its a false economy as the bore of the cylinder will be worn causing the new seal to wear rapidly.
Do it right do it once. Thumbs Up 2005 Td5 90 XS
Steve
Post #261992 28th Aug 2013 8:39pm
ttuck3r
Thanks chaps, Thumbs Up
Post #261994 28th Aug 2013 8:42pm
spudfan
Ireland
From Paddocks
http://www.paddockspares.com/catalogsearch...ehicle=122 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #261998 28th Aug 2013 8:53pm
Happyoldgit
Best replace the slave cylinder at the same time. Steve.
Post #262101 29th Aug 2013 8:18am
