Home > In Car Electronics > Am I doing this right?
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I like to have my iPod music coming through my standard fit (XS) head unit. It the only way I can seem to move through track selection is via the head unto an not my iPod. Is this right or is there a way to navigate the tracks on the iPod itself? It appears to be locked once plugged into the head unit and the controls do not function. Be grateful of any advice.
Post #261567 27th Aug 2013 7:49am
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
My old head unit was the same. I set mine to shuffle, then just skip the tracks I didn't want to hear. I think, there is something you can do to do this differently, but probably depends on the Head Unit.
Post #261577 27th Aug 2013 8:29am
Another thing worth bearing in mind is that on the iPod you can create a playlist of which you can add what you want to play in a list and that will play straight through. So for example you can have a list of singles play one after another in your desired way rather than individually which isn't practical. $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #261581 27th Aug 2013 9:07am
borderterrier
Thanks guys, so there is no way to fwd or reverse etc via the iPod itself?
Post #261587 27th Aug 2013 9:58am
I doubt it... How have you got this connected? If it's 3.5mm aux out I can't see why not? If it's the 30pin plug or whatever it is (or Lightening) then I doubt it. Usually these type are HU controlled or "made for iPod" $W33T $0U7H3RN $UG4R
Post #261596 27th Aug 2013 11:02am
borderterrier
It's via the front USB input
Post #261614 27th Aug 2013 12:19pm
HU controlled then mate. $W33T $0U7H3RN $UG4R
Post #261632 27th Aug 2013 3:24pm
borderterrier
Thanks for your help fella Very Happy
Post #261636 27th Aug 2013 3:45pm
Thumbs Up
I would recommend you create some playlists of what you would like to listen to and use it that way. On some HU's like mine you can control the lot though the HU it's self on more basic models I would imagine it's just rewind forward skip pause and so on. Only way you'd be able to use the iPod is to connect it using the audio jack but you'd lose the charging facility but equally you can add it separately too if required. (Can cause issues though) $W33T $0U7H3RN $UG4R
Post #261641 27th Aug 2013 3:51pm
Cheshire110
I'm quite good with apple stuff-
Through 3.5mm jack the HU has no control - only use the iPod
Through USB iPods and iPhones go into an eternally annoying 'Accessory mode' which means they hand over full control to the head unit (it's the same as with some music systems / TVs etc)
The only way to stop this is to jailbreak your iDevice (a bit risky) - look on youtube if you're interested. I've always had mine jailbroken but I'm fairly capable of sorting out the little niggles that arise as a result.
If you do jailbreak then a tweak such as noaccessoryscreen is what you need.
Personally I use bluetooth streaming on my Parrot Asteroid as quality is good and I can view song details, artwork etc on the screen but fully control music by either the HU or the iPhone. The best of both worlds in my opinion.
Most BT enabled head units will do this nowadays, and they're not too expensive. You're looking at ฃ60-70 for a half decent one. Cheers, David
Land Rovers of all shapes S3 onwardsโ€ฆ Daily is a 110 V8.
Post #261824 28th Aug 2013 8:15am
borderterrier
The head unit in the MY13 is BT enabled so I suppose I can give that a go for the phone, but my music is on iPod classic which has no BT Sad
Post #261863 28th Aug 2013 12:07pm
Cheshire110
Unnecessary quote removed
Yeah I was the same, you don't have much option but to use the clunky interface with USB, set a playlist playing or use the 3.5mm jack and control from iPod. It's frustrating. Cheers, David
Post #261867 28th Aug 2013 12:19pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
And to be more geeky "noaccessoryscreen" is for ios 3 & 4.
For IOS 5 you want "noaccscreen"
Wink I run an Ipad as my incar jukebox and movie player. Awsome setup Cool William
Post #261871 28th Aug 2013 1:07pm
Cheshire110
sounds good! do you have some pictures / a thread somewhere? Cheers, David
Post #261912 28th Aug 2013 3:45pm
