![]() | Home > Td5 > What Prop Shaft |
I replaced mine on my old 90, I bought a double carbon one from paddocks about £250 if I remember correctly
If you are not in a hurry, why not put up a wanted advert in the for sale wanted section, I'm sure someone will have one spare i have one in the garage but I think it's a front prop I'm not sure how you are going to stop someone removing it again Good luck |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5800 ![]() ![]() |
I would buy
http://www.baileymorris.co.uk/4x4.asp (Although I already have brought) Andy |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17590 ![]() ![]() ![]() |
Yes, there should be no problem but drive gently (to reduce driveline stress) and be aware that the handling in front-wheel-drive-only is very different. Don't be caught out on wet roads where you can spin a front wheel easily. |
Oooo Son of a.... There are plenty of second hand props on eBay at the moment. Alternatively try Gwyn Lewis - http://www.gwynlewis4x4.co.uk/page36.html - I have had one of his wide angle front prop shafts (and his suspension kit) for 6 or 7 years now and rate it very highly. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8162 ![]() ![]() ![]() |
Gwyn Lewis or D44 get my vote Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
Gwyn Lewis sells both GKN and Bailey Morris, the BM is IMV the best you can get and the GKN is a close second. Both of them come in at under £200, something like £160 for GKN and £190 for BM.
Alternatively Britpart do a Hardy Spicer propshaft for around £70, the Britpart "own brand" is about £20 cheaper than that I think but I think the Hardy Spicer one is a safer bet ! I run BM on the rear of mine after I twisted the Land Rover one into a neat spiral and snapped it on a steep climb. Having said that though if there's someone watching for your replacement perhaps the Britpart Hardy Spicer one is a better investment as it won't hurt as much if it goes the same way as the last one ! http://www.yorkshireoffroadclub.net/ |
LinDens90XS Member Since: 24 Feb 2012 Location: Merseyside Posts: 83 ![]() ![]() |
Thanks for that guy's, Gwyn Lewis has come up on other forums, only problem is that I don't intend fitting uprated suspension, so may be a wast? or not, any thoughts. Regards
Dennis. |
It's less about articulation and more about strength and durability for me. The BM, in particular, uses a much better sliding joint than the standard part which is not just longer but is smoother and stronger. The UJs are also larger which should also mean higher strength.
The Britpart Hardy Spicer is probably more than adequate for normal use though and comes in at just over 1/3 of the price. http://www.yorkshireoffroadclub.net/ |
Gwyn's props are bailey Morris props. (When I spoke to him last). So buy a bailey Morris direct from bailey Morris would be my vote. Gwyn uses them as they are strong, and have big uj's, which is better for articulation, easier to grease, easier to change uj's. They (BM) are a nice company to deal with. So at the cost its worth it in my opinion. But I have a standard prop here if you want second hand.
Andy |
I'd go for Bailey Morris. Ordered 2 for a friend last week, arrived next day and are well made.
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
As has been said it is about quality and durability. My 110 is now back down to standard ride height but still has Gwyn's prop on and compared to my previous defender with a standard front prop and UJs... I do not go through half as many UJs now... Quality and durability... ![]() |
Just a WARNING to anyone that this happens to, DON'T DRIVE without putting at least 2 nuts on the bolts left on handbrake drum, the small screw holding the drum on came loose and nearly lost the drum but for the silencer stopping it falling off. Regards
Dennis. |
Down to possible three. Bailey Morris, GKN from Gwyn Lewis or from QT. Anyone know who makes QT ones? Regards
Dennis. |
