Home > Puma (Tdci) > Expansion tank leaking
Norm4n
Mine appears to be weeping from the manufacturing joint about half way up
Is there a better replacement part than the standard one?
Post #261456 26th Aug 2013 8:49pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Sure it is not the cap?
These things start to leak every few thousand miles. Here in SA we have a "rule of thumb" that you should replace your cap every 10k km (+_ every 7000 miles). They are cheap (�7 odd per cap from dealers) so worth changing regularly!
Allisport makes a nice allu tank that replaces the standard one. The only issue I have with those is......how the heck do you see the coolant level?
Post #261490 26th Aug 2013 9:48pm
Seen those before too but your point is very valid! I guess you'd have to dip the tank literally just to check?..
IIRC they do others too i.e. PAS fluid. But the point in it is next to none IMO. They aren't even some nice trick colours just raw silver. Neutral WeWillWin🇬🇧🇺🇸
Post #261500 26th Aug 2013 10:08pm
Norm4n
Thanks for the replies.
I check my coolant level with me finger Laughing
Post #261574 27th Aug 2013 9:18am
I can't see the level in the standard tank and always use a pencil to dip it.
Post #261575 27th Aug 2013 9:25am
e.khromtsov
Russia 2007 Defender 110 Puma 2.4 SW Stornoway Grey
I just shake the tank a little, and the fluid level becomes visible.
Post #532247 17th May 2016 9:06am
nickhodgson
Shine a torch against the side of the tank and you will see the level of fluid. I would also check that its not the cap leaking - I have had a few leak. In hot climates when the cap leaks it can lead to overheating...... 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #532249 17th May 2016 9:18am
AlanH
Australia
Mine seems to leak if I fill it up to the level mark. Then on a long run it drops maybe 2cm but no further! I'll do as others do and get a new cap to se if that makes a difference.
AlanH.
Post #533357 21st May 2016 9:41am
KGH
United States 2013 Defender 110 Puma 2.2 HT Keswick Green
Have leaking coolant tank and smell of antifreeze. It looks like manufacturing joint to me, as no fluid residue from cap.
Goes in for intermediate shaft work (!) on 6/6, will add this to list!
Post #535315 28th May 2016 5:06am
Retroanaconda
Splitting at the seam is a common fault on older Land Rovers.
With regard to the caps, must be a hot country thing as I've never heard of people needing to change them on a regular basis. Mine is date-stamped 1991 so has seen its fair share of use.
Post #535342 28th May 2016 9:10am
Happyoldgit
I've had to replace the expansion tank caps on a couple of my previous Puma's but don't recall them failing on previous models I've had. For whatever reason I definitely think it's a Puma thing. Steve.
http://forums.lr4x4.com
Post #535378 28th May 2016 1:37pm
dgardel
Italy
better and definitive solution
P/N is IVECO 99489567
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #535387 28th May 2016 2:45pm
geobloke
Has anyone UK based managed to find this Iveco I99489567 cap? if so where from? not having much luck...
Post #653351 28th Sep 2017 10:45am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Try cheap Iveco parts.com
01923840154
Use them all the time for work, if they haven't got it, you won't get it! Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #653358 28th Sep 2017 11:17am
geobloke
Good man Ian Thumbs Up
Post #653361 28th Sep 2017 11:21am
