![]() | Home > Maintenance & Modifications > Will foxwing awning fit on a 110 Front Runner roof rack? |
a13x Member Since: 25 Sep 2011 Location: Burton on Trent Posts: 553 ![]() ![]() |
I've not done it yet but I can't see why not. That being said I have the foxwing and a set of brackets purchased through Brendan but can be seen on the Boab website. Believe they were £50.
These are specifically for the foxwing to mount to a rack like the frontrunner and is what I will use when the hannibal rack finally arrives. |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
Yup
The standard brackets supplied with the Foxwing is designed to fit on the Rhino Rack roof bars.
You might be able to adapt them to fit the Front Runner roof rack. However depending on your height, your vehicle set up you might struggle to put the Foxwing away due to height above the ground. We do have the Tracklander fitting kit in stock although they are not on our website at the moment. Any questions ask away. Brendan |
Odin Member Since: 29 Apr 2011 Location: Aberdeenshire Posts: 237 ![]() ![]() ![]() |
Thanks Brendan. So with the brackets I can fit the foxwing awning to the front runner rack. How much for the brackets?
Brackets are £50.
If you pm me your delivery post code will work out best delivery option and cost. Brendan |
Thanks Brendan for your time today - great advice as ever. Will be in touch to place order once I've the cash.
