![]() | Home > Maintenance & Modifications > Fitting Roof Rack Spot Lights - Puma 110 |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 504 ![]() ![]() ![]() |
Hi Bruce, No, you can't wire the switch like that, for two reasons - 1: The Illumination and Tell-Tale are LEDs and will only work in one direction. 2: Pin-3 and Pin-4 are commoned. However... ![]() You can easily modify the switch's internals to make it switch as you want ![]() This is what the switch looks like inside (bad photo alert ![]() Here's a picture of the inside of the switch, which I've annotated with the terminal numbers and to show how the contacts connect accross pins 1 & 4 when in the ON position - ![]() Click image to enlarge This is a close-up of the switch's circuit - ![]() Click image to enlarge It's easy to convert this switch to a conventional live switching ON/OFF switch by cutting the brass track between the two holes, as marked in red in this next picture (I've use a Needle File to do this on the ones that I've modified) - ![]() Click image to enlarge By cutting the track at this point, you separate pins 3 & 4 The revised circuit is now - Pin 1 - Incoming Live from Main Beam/Dipped Beam/Side Lights (as applicable) Pin 2 - Live from Dash Illumination Pin 3 - Switch Earth (for indicator LEDs) Pin 4 - Switched Live output to Terminal 86 of your Relay Pin 5 - Live in from Pin 4 (for Orange 'tell-tale' LED) You could link pins 4 & 5 inside the switch while you had it apart, by soldering a link across the brass tracks but I would just crimp an extra short length of cable into Pin 4 and loop it round into Pin 5 on the connector. You will still need to use an accessory relay with a switch modified in this way but, at least it will be wired in a conventional manner. Paul. . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 20th Mar 2012 10:58am. Edited 1 time in total |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
Thanks Paul..
What do you mean by accessory relay? Is this the spot relay? |
Yes, to terminal 86 of the spot lights relay. I've edited my earlier post. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Ah thank you. Let me try that. It would be easier than undoing the harness I made.
Will let you know how it goes. Thanks again. |
Paul I owe you many, many cold ones if you are ever in South Africa. Got it working and very chuffed. Thank you.
Bruce, I'm happy to help ![]() . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
v40mav Member Since: 25 Aug 2008 Location: UK Posts: 206 ![]() ![]() |
Got all the lights done but used a standard rocker switch for one of the pairs as I didn't want to pay nearly £50 for the second genuine switch - previously under a tenner - !!
( Switches are YUG000540LNF - ) Anyone know of a supplier or source where these can be had at a sensible price - ? Defender 110 County SW Disco 3 HSE Freelander 2 HSE - SOLD going back to a car www.lothian4x4response.org |
I cant remember where i ordered mine but they werent that expensive. Perhaps send Paul a PM and ask him as I bought my plug thingy s from him......
Unfortunately, YUG000540LNF, along with several other Defender and Discovery II switches, went up in price earlier this year, to 'silly-money' prices. You will struggle to find anyone selling them at pre-increase prices (including those who had stock before they went up ![]() If you're making your own roof lights loom, then the cheapest option for a factory fit switch is the Puma Heated seat switch YUF500150LNF ![]() Click image to enlarge This switch is still around a fiver ![]() It uses the Black switch connector and, unlike YUG000540LNF, it switches the live and not the earth. It is wired, as follows - Pin 1 - Live in from fused supply Pin 2 - Dash illumination Pin 3 - Not used (but is internally connected to Pin 5 - Earth) Pin 4 - Switched live out to accessory Pin 5 - Earth The 'heated seat' switch cap can be replaced with the blank cap from the blank that it's replacing on the facia. This blank cap can be modified, with a 2.5mm hole, for the 'lense' for the Orange tell-tale LED to poke through. You could engrave a suitable symbol onto the blank cap - this would allow it to illuminate with the dash lights. Or, you could use a stick-on symbol from VWP or MUDSTUFF, which won't illuminate with the dash lights. . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 1st Sep 2012 1:05pm. Edited 4 times in total |
So I got mine just in time......
Know it is a while back. But blooming brill idea... Well done that man... :bow: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404 ![]() ![]() ![]() |
yup, this thread will be invaluable when I come to wire up roof rack lights
![]() CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 255 ![]() ![]() ![]() |
Can anyone tell me the best way through the bulkhead (on a Puma), from the engine bay to behind the dash. I'm wiring up 4 x lightforces, as shown below (fuses not shown):
![]() Click image to enlarge I can't see a grommet to take it through, although I have found a smallish hole covered by a black sticker that a won't fit a grommet, although I may be able to enlarge it. I've got a Mud Pod for Carling On-Off-On switches to sit on top of the dash. Also, what's the best way to attach the wiring as it runs up the snorkel? My Disco 'best bits' Defender 110 XS CSW 2013 |
I pulled my wiring through a grommet behind the instrument cluster. (right hand drive)
To attach to the snorkel I used some zip ties.....not the prettiest option but doesn't look bad/hardly noticeable. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
