Home > Puma (Tdci) > Many Thanks Chris@CSK
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Just wanted to say a big thank you to Chris Kill for his help last week. I've just completed an 1600 mile trip around France and back in my Puma 110. Drove well and with the Dynamat sound proofing front to back and the Bell remap it was quiet (for a Defender!) and fast.
I had a small film of oil on the underside of the bonnet (above the screenwash bottle - blown back by the fan) when I reached Bordeaux. Bit concerting so I contacted Chris via text - 10 minutes later he was on the phone with some pointers/ideas of where it was coming from. Suffice to say after checking a couple of bolts and tightening them up it doesn't leak anymore after another 500 miles.
Cheers Chris, top bloke Thumbs Up Thumbs Up Cheers,
Superspoons
Post #259824 19th Aug 2013 9:53am
Killer90
Site Sponsor
Thumbs Up Really appreciate the good feedback and glad you got home safely Mr. Green Mr. Green Anytime Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #259853 19th Aug 2013 11:36am
JSG
So where was the oil coming from? John
2011 Tdci 110 CSW XS
Post #260234 21st Aug 2013 8:12am
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Yes, me want to as well!
I think I might have the same issue?
Post #260248 21st Aug 2013 9:41am
superspoons
Its really difficult to trace because at the time I couldn't remove the fan to see where it was coming from without it getting blown backwards towards the engine.... Confused
I tightened the bolts on the front of the timing cover....one was very loose and checked all the hoses for splits/clips. I also checked all visible bolts in the area and tightened where appropriate as advised by Chris. It stopped the leak and I had no more problems when driving around locally on short trips... until I looked underneath yesterday and have a palm size pool of oil directly under the breather pipe on the front axle after it has stood overnight after a 400 mile trip Big Cry I cleaned it up, re-seated the axle breather pipe and so far all good - no more leaks. Could it be pressure build up in the axle I wonder... Question
Still not 100% where it is coming from TBH. It only appears to do it after a long run at speed. Its a minimal amount but needs addressing... will whip the fan off this week and take more in depth look. Cheers,
Superspoons
Post #260270 21st Aug 2013 10:59am
Regard
I have a very faint oil spray mark (really just a line of very fine oil marks) under the bonnet. almost directly behind the washer bottle and directly above the brake vacuum. I was worried that it might be the brake vacuum that is strating to leak (this is a well know point of faillure...?).
I have tried to see where it is from but i can not find any "wet" areas anywhere close to the brake vacuum?
NO OIL on the ground or anywhere to be seen for that matter.
Will post pic later.
Post #260278 21st Aug 2013 11:35am
superspoons
Here's the leak... I know... not very interesting (directly below the breather pipe)
Most of the oil was concentrated around here but I think it was being blown up from underneath:-
Oil was appearing underneath the bonnet on the right hand side above the washer bottle back to the heater box (I'd cleaned it off when this pic was taken)
Great new way to upload photos BTW Thumbs Up Thumbs Up Cheers,
Superspoons
Post #260306 21st Aug 2013 12:46pm
Glynparry25
Vacuum pump is known for its problems (if it is the earlier one (changed some time in 2009)). Very cheap and easy change Thumbs Up But not known of any 'starting to go' normally noticeable by quite a bit of oil.
Glyn Dog Sheep
Post #260309 21st Aug 2013 12:51pm
Regard
Glyn Dog Sheep
Mmmm...
Mine is a 2011 X-Tech 110.
So supposedly the "new" vacuum pump.
And it is minimal amounts. I've been involved in a full blown vacuum pump.....nasty....whole engine sprayd with copious amounts of oil.
So hopefully not that....but from where then?
Post #260316 21st Aug 2013 1:05pm
Glynparry25
Possibly the gasket (pump to engine block), rather than the pump seal? Mine was as you described- oil all over engine, bonnet and even on the wing top.
Glyn Dog Sheep
Post #260318 21st Aug 2013 1:18pm
superspoons
It's interesting you mention the Vacuum pump as the oil was congregating around the gasket where it bolts on.. perhaps it has gone. My 2.4 is late 2008 build so you may have something there... Thumbs Up
Just found another pic I took at the time of the vacuum pump:-
I've just searched the site and ...
http://www.defender2.net/forum/topic16139.html
So, ordered a new one from local dealer and will fit and report back. They confirmed a new gasket(s) for the pump following initial failures. Cheers,
Superspoons
Post #260320 21st Aug 2013 1:23pm
Glynparry25
Vacuum pump probably came up with many replies.
When mine went I got the replacement unit (Double seal) and the gasket- for a few £ there is no point scrimping on it. That was 2 years ago and no problems since *Touches wood*.
Plus you don't really hear of them going any more.
Glyn Dog Sheep
Post #260321 21st Aug 2013 1:31pm
superspoons
Glyn Dog Sheep
Just what the parts guy said. They use to keep them on the shelf as they were always going, but now they don't see that many failing, so they are an order item from LR. Cheers,
Superspoons
Post #260323 21st Aug 2013 1:37pm
Regard
If you can spot it.......
Post #260328 21st Aug 2013 2:02pm
Glynparry25
Rolling with laughter Rolling with laughter
Shocked I see the problem...... your bonnet is FAR too clean, are you related to Zagato? lol. TBH, if that is all there is there isn't much need for concern- just keep an eye on it every now and then and wait to see if it gets worse Smile. Or were these pictures after a clean?
Glyn Dog Sheep
Post #260333 21st Aug 2013 2:09pm
