Home > Maintenance & Modifications > Fitting a volt meter
excossack
I have a volt meter in the form of an analogue 52mm guage. Whats the prefered way/best way of wiring in the guage to a TD5 110? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #260109 20th Aug 2013 5:25pm
bob neville
I connected mine to the switched live to the radio.
Seems to work OK Thumbs Up
2013 Defender 90 CSW - sold
Post #260116 20th Aug 2013 5:44pm
excossack
Seems sensible to me. I was thinking of fitting a toggle switch so I can get the voltage of the 2nd battery as well. 1999 Defender TD5 110
Regards
John M0VAZ
Post #260122 20th Aug 2013 6:02pm
JWL
I wired mine directly to the batteries so I can read the state of them both via a simple on/off/on switch. I went to the batteries to eliminate any voltage draws through the loom. I can also watch the charge voltage when the engine is running.
Post #260128 20th Aug 2013 6:23pm
excossack
and I guess that way you can also check the status of the batteries without having to turn the ignition on. 1999 Defender TD5 110
Regards
John M0VAZ
Post #260180 20th Aug 2013 8:41pm
JWL
Yep Thumbs Up
Post #260193 20th Aug 2013 9:16pm
excossack
Sounds like a plan to me. 1999 Defender TD5 110
Regards
John M0VAZ
Post #260195 20th Aug 2013 9:18pm
