Home > Maintenance & Modifications > JW Speaker Led Lamp corrosion
Page 2 of 6 <123456>
ericvv
Post #258911 15th Aug 2013 6:30pm
dgardel
Italy
ericvv wrote:
dgardel wrote:
Passivation finish is not sufficient with stainlees steel ring. It make a lot of oxidation.
Good solution is put silicon grease on the internal side of the ring.
This stuff?
http://www.amazon.de/Liqui-Moly-3312-Silic...m_sbs_sg_1
It is ok
Evo passivation isn't able to stop the corrosion my old 8700 after 2years was perfect (the secrets is do not damage the black paint with the ring), the new evo made oxidations after 2 months. I had to put the silicòn grease.
By the way, nolden case quality seems better.....
If you look closer the JWS, in my opinion, the company have quality problems and not all pieces was made with the same precision (eg different beam pattern) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #258913 15th Aug 2013 6:39pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
my EVO's are fine in Derek the 90, its the corrosion on the rest of him i'm worried about... Whistle Putting Dreams on Drives at JLR Solihull..
Post #258916 15th Aug 2013 6:49pm
dgardel
Italy
http://www.blacklandy.eu/blboard/forum/sho...LED/page13
http://fred95-defender.blogspot.de/search/label/Nolden Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #258923 15th Aug 2013 7:07pm
ericvv
Anybody else cared to check the backside of their Speaker 8700 EVO's for eventual reaction with the SS rings and corrosion?
We now already know that Daniele had such corrosion after 2 months which is no good.
I intend to order a tube of this Liqui Moly silicone grease to avoid corrosion to start. (Hopefully there is none yet, cross fingers). I also have the SS rings which seem to react with the alu of the Speakers, but have not checked yet, which will do during next service two weeks from now.
In the meantime think this thread is worthwhile to keep alive, so if others have bothered to check, would be good to hear result, and this could be indicative of how serious a problem it is. We talk about very expensive upgrade equipment here which many of us have bought, so worth doing all we can to identify risk and take preventive or corrective action. Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #259429 17th Aug 2013 6:18pm
Killer90
Site Sponsor
I have a pair of the river runner JW speaker sidelights here which have completely corroded up Big Cry Big Cry
Apart from that they are the nuts Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #259430 17th Aug 2013 6:30pm
ericvv
Post #259431 17th Aug 2013 6:32pm
Killer90
Site Sponsor
Big Cry i might rub them down and paint them colour coded for the trayback Laughing CSK Automotive
Post #259435 17th Aug 2013 6:43pm
Likeomg
same on backs of mine... well corroded
Post #259464 17th Aug 2013 9:12pm
ericvv
Think alarm bells are starting to go off here, even if we sofar have only limited nbr of confirmations that these Speaker 8700EVO do corrode when in contact with steel or stainless steel rings.
Time for someone to start thinking of what we can do to either still avoid this corrosion from happening, or if it already is happening, what can be done to stop it to deteriorate the rear of the lamps further.
Only thing we have seen sofar is that Daniele (dgardel) advised to use silicone grease in between the rings and the lamp, but is that sufficient action, especially to stop a process which is going on already.
Silicone grease good enough? Can it also stop already started/progressing corrosion? Are there other things that can be done, etc....... As said I will have mine checked in a few weeks now, will let you know then.
I also think that Tim of Mobile Centre who is the or a major importer, has to wake up to this concern, and take the bull by the horns if necessary.
Post #259475 17th Aug 2013 9:46pm
Welshsurferdude
Wales
I have Nolden LED Headlights on mine and I have dunked them in deep mud etc and done a winter in these so I will check them as I kept my original headlight rings and they are rusty so need to replace them anyway! 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #259476 17th Aug 2013 9:50pm
Pickles
I don't think anyone was having a go at a sponsor. Speaker lights appear to have an awesome reputation, but if there was an issue with them, then I'm sure that the sponsor, who also has an awesome reputation, would want to know about it.
Cheers, Pickles.
Post #259529 18th Aug 2013 3:41am
ericvv
Cheers, Pickles.
Pickles, not sure if you are responding to any particular post in this thread, but you are correct. I think a huge number of people have paid significant money for these Speakers, and would expect them to be as high quality manufacturing standard as has been advocated. If now it appears that there is an issue with multiple users having them corroding, it indeed is important that this gets known, and that those marketing them (Speaker/importer/distributor) are made aware of this so that they can define their actions.
So in the first place it is important that other users who will check their installed lamps will report back here, be it positive or negative.
Post #259531 18th Aug 2013 5:18am
Pickles
eric....that is exactly what I was trying to say.
Cheers, Pickles.
Post #259570 18th Aug 2013 10:11am
Forum Sponsor's response seems quite clear - "if corrosion affects the operation of the lamp subject to normal criteria we will exchange the lamp for a new one." and implies the corrosion itself is not a warranty issue.
Post #259624 18th Aug 2013 3:16pm
