![]() | Home > Puma (Tdci) > right door window offline |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 ![]() ![]() ![]() |
Hi guys,
I'm here today to ask for your guidance and wisdom. Here is the thing.: mine is a 2007 defender, i have front doors electric windows and the right yesterday decided to stop working. Luckily it happened while closed. Now, this morning i have read the wiring manual, removed the door card, opened the dash, found my trusty tested and started the investigation. Result: 1) it s not the switch, all wires that go in/out there carry current as expected. 2) it is unlikely that is the motor but i cannot rule it out completely 3) of the 2 wires that go on the motor, one carries current, the other doesn't. In fact if i probe one of the 2 i get a reading (which goes away if i click the switch on the dash) while the other is constantly dead. Now my questions: 1) am i right in my assumptions that it might be a wiring problem? 2) the electric diagram shows that the wires from the switch go to some intermediate connector. Where is it? If i find it my plan is to check if the current is lost before or after that? Thanks in advance |
The first thing I would be checking is the state of the wires going from the bulkhead to the door, much like central door locking problems the cause will be a wire broken in the part of the loom that flexes when you open and close the door, the most vulnarable part.
That's curious... now it seems behaving opposite. When i press the switch the current goes. I'll open the door card again and check the loom that comes from the dash. |
A post to door wiring in the rubber boot will be snapped as said above
You guys are unbelievable!!! Job done, it was indeed a cut wire in the loom that enters the door (blue wire, window down)
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Glad to hear you got it sorted.
![]() We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 ![]() ![]() ![]() |
![]() Click image to enlarge And another one, voltage on both wires coming from the bulkhead. 2005 TD5 90 CSW XS |
Zim Member Since: 25 Jul 2013 Location: Small Village, south side of Leicester Posts: 86 ![]() ![]() ![]() |
Check the other wires while you are there. I had exactly the same issue, the blue had broken but when I looked at the red, it was weak and was pretty close to failure too. You don't want to have to do the job twice. 2007 Defender 90 XS
2022 Defender D300 HSE X-Dynamic |
Yes the other one was also cracking so replaced them both with new better quality cable, thank you for the advice 2005 TD5 90 CSW XS
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
I have the same problem. Not for the first time. Both wires have broken in the past and have been replaced. This time the readings are correct so what is wrong? Peter
