![]() | Home > Puma (Tdci) > elbow room |
Yes open the window
Simple .......Open the window...like the rest of us
![]() ![]() 110 HCPU Tipper |
Beat you to that Willy
Beat me 'n' all! Then again my (and Willy's) first post was significantly earlier than yours today Fekete! What's up alarm failed to go off?
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
You're only right again Mal just on my first Brew
PumaGreg Member Since: 04 Mar 2009 Location: UK Posts: 80 ![]() ![]() ![]() |
Try doing 300,000 miles in different Series and 90s.............my elbow is now so mis-shaped, it fits perfectly!
![]() Currently: 2013 90 2.2 Puma Base Station Wagon 1991 90 Tdi 2015 Discovery Sport 2.2 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2454 ![]() ![]() ![]() |
If you have troubles with your right elbow, drive a LHD landy
![]() ............................................................. Earth first. Other planets later Last edited by MK on 5th Mar 2010 12:55pm. Edited 1 time in total |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 ![]() ![]() ![]() |
lean over a bit and put your other elbow on the centre console...
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 ![]() ![]() ![]() |
one of those things that makes us love the landy.
you actually get used to it...but if you can't...I drive a LHD and I find that if I lean to the right, resting on the cubby box left hand on the wheel all cool looking and put my wallet with all the receipts of the dealer under my left bum cheek, it is quite comfy. ( hope you all got a mental picture..that is what I was shooting for) Oh, also, it makes you look even cooler if you wear some shades... ![]() IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
I learned to drive on a LHD in the US, and drove LHD cars for years, so I've got a tendency to lean a bit to the left (against the door) - which works out well in my RHD 110 'cos I lean towards the cubby box.
However every now and then I forget how tight the space is. This AM, during some fast wheel-turning I bashed my finger into the door window. The lack of space is a thing that you get used to, and I rather like it... in a masochistic sort of way. ![]() |
Knot Yet Member Since: 01 Mar 2010 Location: West Sussex Posts: 197 ![]() ![]() ![]() |
It's certainly a unique driving style and one you eventually get use to
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Goes with the territory, I'm afraid.
If you were to offset the seat, you'd end up out of line with the pedals. They can't be moved so I'm afraid you have to get used to it (I don't even notice it now). One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
It all makes sense when you're off road, stops you getting chucked about, I like a nice tight fit.
Also means that you're right on the line of the wheels so easy to lean out and check your placement. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
