![]() | Home > Td5 > silly questoin about battery and ECU |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
No, the ECU file is stored in the ECU and doesn't disappear if the battery is disconnected (although, thinking out loud, I wonder how long it would stay there, or if the ECU has a battery inside it....)
the speedo mileage is held in a processor that has bytes erased in it, to show the current figure, so that won't erase, but the trip is held by the vehicle battery, so that will reset to 0 if the battery is disconnected. |
MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 137 ![]() ![]() |
HI
well the land rover in question has been sat there for a lot of time, (that white one i linked over here still thinking of trying a test drive if still there ![]() When you refer to trip - does it mean a trip meter? i don't think it had on the speedo - just recorded mileage (unless found on ecu.) thanks joseph |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
The MAP or fuel file is probably held in NVM (non volatile memory) so a power loss should not affect it at all .....otherwise there might be a lot of 'dead' Defenders around...........
![]() JD 2008 TDCi 2.4 XS CSW |
your comment makes sense. funny i cannot remember who told me so...
probably i was talking to a td5 about avoiding fires by doing a battery isolator in periods of not use but he told me it might cause problems to ecu. cheers all joseph ![]() |
I have never seen a manufacturer state that long term storage would cause problems with an ECU, as it's very common to park a motorbike up for 6 months in the winter with the battery in the house on trickle charge,it's normal for the ECU to re-adjust slightly once the engine is re-started.I had a KTM motorbike and I think Corsa's that once engine is re-started (after battery disconnection) do not use the throttle for 10-15 minutes,to allow ECU to adjust.
And you don't lose the information on a flash drive when it's not being used. |
