Home > Puma (Tdci) > Are Pre 2.2 ABS modulator units the same as TD5 units?
Landyphil
United Kingdom 2003 Defender 110 Td5 USW Stornoway Grey
Just had a peruse under both bonnets.
Both units look the same.
They have the same wabco codes only the serial number seems different.
They have the same plugs with even with the same colour codes and cores.
New Puma ABS unit £2,200+vat. Second hand td5 unit...a chuffin lot less!
Can you tell what's just shat itself on the Puma 90? Evil or Very Mad 90XS Tdci John Eales
110 CSW G4 Edition
88" Series 3 Racer
Post #257567 9th Aug 2013 4:59pm
Thor
United Kingdom 2002 Defender 110 Td5 CSW Bonatti Grey
I'm having the same issue on my TD5. After a bit of research I was directed to www.ecutesting.com. A couple of people have had some success with them. I mentioned it to the garage I use (MID Engineering) and as a test he sent one up from a freelander, now that's back and repaired mine is out and in the post to ecu testing as I type.
http://www.defender2.net/forum/topic20998.html
Holefully a quick read through that and maybe get in touch with ecu testing will help and save you a load of ££££. I've not spoken to ecu as the garage has done it all so don't know what they're like to deal with. Worth a shot though! Strong people are harder to kill and generally more useful!
Post #257581 9th Aug 2013 5:47pm
dgardel
Italy
Puma 2.4 up to MY2010, ABS is WABCO (same as td5)
Puma 2.4 MY2011, ABS is BOSCH
Puma 2.2 MY2012 and newer, ABS is BOSCH Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #257617 9th Aug 2013 7:51pm
dgardel
Italy
Ouch double post Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #257618 9th Aug 2013 7:51pm
