Home > Puma (Tdci) > Are Pre 2.2 ABS modulator units the same as TD5 units? |
Thor Member Since: 17 Dec 2011 Location: Didcot Posts: 446 |
I'm having the same issue on my TD5. After a bit of research I was directed to www.ecutesting.com. A couple of people have had some success with them. I mentioned it to the garage I use (MID Engineering) and as a test he sent one up from a freelander, now that's back and repaired mine is out and in the post to ecu testing as I type.
http://www.defender2.net/forum/topic20998.html Holefully a quick read through that and maybe get in touch with ecu testing will help and save you a load of ££££. I've not spoken to ecu as the garage has done it all so don't know what they're like to deal with. Worth a shot though! Strong people are harder to kill and generally more useful! |
9th Aug 2013 5:47pm |
Puma 2.4 up to MY2010, ABS is WABCO (same as td5) Puma 2.4 MY2011, ABS is BOSCH Puma 2.2 MY2012 and newer, ABS is BOSCH Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 9th Aug 2013 7:55pm. Edited 1 time in total |
9th Aug 2013 7:51pm |
Ouch double post Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
