Home > Td5 > Half moon leaking at back of engine
jwhat
Ireland 2008 Defender 110 Puma 2.4 DCPU Keswick Green
The half moon shaped bit of the cam gasket seems to be leaking, is it straightforward take old one off and stick new one on and torque bolts correctly? Any particular order for the bolts or do I need a sealant as well? Genuine parts only or are bearmach/all makes ok? Tdci 110 DC
Post #256708 6th Aug 2013 1:47pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
very easy to do should take no more than 15 minutes, remove engine cover, remove the bolts around the rocker cover leaving pipe attached on top remove old gasket, fit new gasket (suggest wipe gasket with a little oil to soften slightly) put rocker cover back on and do up bolts making sure rubber gromets are in correctly hand tight is ok and refit engine cover job done
Very Happy Very Happy 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #256713 6th Aug 2013 2:02pm
jwhat
Thanks pj2106, another job for the weekend. Tdci 110 DC
Post #256733 6th Aug 2013 3:08pm
I refitted my (old) seal with some silicone type gasket stuff (the proper red stuff for making gaskets) and it's not leaked yet
Post #256735 6th Aug 2013 3:12pm
MichaelHead
England 2006 Defender 90 Td5 HT Tonga Green
You might as well change the loom while your at it
Post #257062 7th Aug 2013 6:56pm
stevetd5
Australia 2002 Defender 110 Td5 SW Alpine White
I always fit a new rocker gasket, not too dear and its better than having oil down the back of the engine. Also you can get replacement o rings rather than replacing the whole injector loom.
Post #262392 30th Aug 2013 12:56pm
jwhat
I changed the injector harness, cam cover gasket and both camseals last weekend. I just went for PR2 Allmakes stuff, harness was never changed it was stamped 2005! Running a bit better now and the leaks seem to have stopped but I need a new MAF, its been an expensive month! Tdci 110 DC
Post #262397 30th Aug 2013 1:14pm
