Home > In Car Electronics > New DAB radio aerial issue
madrunner
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Evening you clever lot,
Need some pointers - I'm installing a pioneer DAB head unit into the habitation area of our motorhome.
All the wiring is easy as the 12v supply is right where I need it, already dragged out the speaker feeds which ill cut and use.
Now for the aerial question - I already have a fitted aerial with signal booster that handles DAB and has a standard F type connection.
The pioneer has the usual fm aerial and an additional tiny snb connection.
How do I get all 3 together and where on earth do I find the fittings ?!!!!
Google search proving useless....
Cheers all Bow down
Post #255385 1st Aug 2013 6:14pm
johnnyd
I would have thought you just need an F to smb connector ......anything here do ?
http://stores.ebay.co.uk/chinarf/SMB-Adapt...=573264819 2008 TDCi 2.4 XS CSW
Post #255388 1st Aug 2013 6:23pm
madrunner
Cool cheers for that.
Now how to integrate the standard FM aerial input to that ?....
Yours confused.
Post #255393 1st Aug 2013 6:40pm
Nick-St
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Ate you sure the DAB antenna is also an FM antenna?
Post #255612 2nd Aug 2013 11:42am
madrunner
There are 2 seperate aerial inputs - DAB and FM but I've found a couple of leads from Dabonwheels that with a small modification will work !!
Post #255616 2nd Aug 2013 12:03pm
johnnyd
I think what we are trying to say is the DAB antenna will not pick up FM transmissions, also be careful about connecting dab aerial outputs on radios to standard fm aerials, they carry volts I think to power the dab aerial
JD 2008 TDCi 2.4 XS CSW
Post #255618 2nd Aug 2013 12:10pm
madrunner
Cheers for that JD.
Yeah I've already got a powered DAB signal from the MH so I'm going to seperate the FM input from the lead set ive ordered and with a bit of luck it should work.
He says. Lol
Post #255621 2nd Aug 2013 12:32pm
