![]() | Home > In Car Electronics > New DAB radio aerial issue |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
I would have thought you just need an F to smb connector ......anything here do ?
http://stores.ebay.co.uk/chinarf/SMB-Adapt...=573264819 2008 TDCi 2.4 XS CSW |
madrunner Member Since: 24 Jul 2012 Location: Dorset Posts: 68 ![]() ![]() ![]() |
Cool cheers for that.
Now how to integrate the standard FM aerial input to that ?.... Yours confused. |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 ![]() ![]() ![]() |
Ate you sure the DAB antenna is also an FM antenna?
There are 2 seperate aerial inputs - DAB and FM but I've found a couple of leads from Dabonwheels that with a small modification will work !!
I think what we are trying to say is the DAB antenna will not pick up FM transmissions, also be careful about connecting dab aerial outputs on radios to standard fm aerials, they carry volts I think to power the dab aerial
JD 2008 TDCi 2.4 XS CSW |
Cheers for that JD.
Yeah I've already got a powered DAB signal from the MH so I'm going to seperate the FM input from the lead set ive ordered and with a bit of luck it should work. He says. Lol |
