Home > Puma (Tdci) > tdci kenlowe fan
bear100
tdci kenlowe fan
is there any advantage to fitting a kenlowe fan to a tdci?
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #255262 1st Aug 2013 1:45pm
No, although other views are available Laughing Darren
Post #255264 1st Aug 2013 1:51pm
Egghead
If you are after better fuel economy then probably not much advantage gained with an electric kenlowe over the reliability lost from the viscous fan. With the off road tyes, roof rack, light bar and bolt on extras I have fitted to my Defender, the marginal fuel savings I will make are near to none I reckon - although Kenlowe possibly claim 10% fuel savings!! (Maybe if I didn't drive like I've stolen it I would have a better chance also - maybe come close to 0.1%??)
Post #255279 1st Aug 2013 2:37pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
If an electric fan was better Land Rover would have fitted one.....But then again. Whistle 2005 Td5 90 XS
Steve
Post #255281 1st Aug 2013 2:42pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Nope, biggest load of overhyped 'claims' ever ..... yet 25 years on people still believe they will see a marked difference in mpg and performance Rolling with laughter
Save your money Wink Guns and Landrovers .... anything else is irrelevant.
Post #255352 1st Aug 2013 5:36pm
Lou Sparts
If you want to see the difference in performance an electric fan will make take your existing fan off and go for a drive.(Same principal applies to performance air filters). 2005 Td5 90 XS
Steve
Post #255354 1st Aug 2013 5:43pm
jst
Bigwheels had a post on this a month(?) ago Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #255530 2nd Aug 2013 7:29am
Dieselhead
If you value your head gasket then keep the viscous. Esp if you tow alot
I had a kenlowe fitted to my D2 for a while. Did not notice any difference in fuel so flogged it an the car Laughing
Wast of time & money if you ask me Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #255675 2nd Aug 2013 5:44pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
i bought my tdci with one in it and you would be surprised to know that it NEVER comes on.
Even on the hard climbs in this recent heat we have had the guage stays bang on the centre mark. The factory radiator is fantastic. I also have the bigger intercooler which will restrict movement around there too. William
Post #255682 2nd Aug 2013 6:10pm
jst
and keep coolant temps down
my viscous is locking up with the recent weather and hard pulls Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #255698 2nd Aug 2013 7:09pm
jst
http://www.defender2.net/forum/topic21221.html Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #255702 2nd Aug 2013 7:12pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Just so that you are aware William8, the temp gauge never moves on my 09 Tdci either. However the Scangauge 2 tells me that the engine temp occasionally gets up to 110C causing the Engine Management to kick in and kill the power. The gauge never moves past the halfway mark. Hopefully your electric fan is thermostatically controlled and setup correctly rather than on a manual switch, otherwise you might eventually do some damage to your vehicle.
Might be worth a check just to make sure it is working correctly and kicking in at the correct/desired temperature.
Regards,
Mark
Post #255725 2nd Aug 2013 8:00pm
william8
Regards,
Mark
Thanks Mark i will look into it. Although i do notice you in Dubai? makes a difference and i thought i could at least rely on a land rover thermostat Laughing ah well
Thermostat is factory set at 95 decrees C i tried getting it to come on when i installed it but the needle wouldnt rise and the fan wouldnt come on.
william William
Post #255849 2nd Aug 2013 11:20pm
Temp gauge on Puma is driven by the instrument pack and is programmed to display normal (ie it doesn't move) throughout the engine's full normal operating temperature range. It really has very little bearing on the actual temp.
Post #255850 2nd Aug 2013 11:20pm
pope10001
william
Hi William,
Yes I'm in Dubai and yes it does get a fair bit hotter over here. Even when it's 50+C out here the temp gauge never moves past half, although the actual water temp raises a lot. Are you sure the thermostat opens at 95C? That seems a little hot to me. My engine temp runs at around 86C most of the time which suggests a lower opening temp, but it may be different for the Middle East market.
Either way, you should be able to get your fan to come on by just letting your car idle for long enough, if it doesn't then I would say that you have a problem. You should have a separate temperature sensor for the electric fan somewhere, these normally have some adjustment on them so that you can get the fan to come on at your desired setting or they are set to come on at a per-designated temperature.
Regards,
Mark
Post #255859 3rd Aug 2013 3:57am
