![]() | Home > In Car Electronics > How do I remove Carling switch connector? |
from the other side slide a thin metal blade between the plastic & brass connector then pull from the other side
I haven't got these switch connectors on mine
![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
TheWarden Member Since: 25 Feb 2013 Location: Southampton Posts: 179 ![]() ![]() ![]() |
That'll be one of those relay type holders for a carling switch. From the other side you should be able to slide a thin blade screwdriver or something similar down the side of the connector to release the little clip that holds it in place then, at the same time pull it out from the back 2013 Aintree Green 110 Station Wagon SX
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Done it. Thanks guys
![]() The +ve wire was touching the other connectors which I think is the cause of some strange problems I encountered yesterday, posted here.... http://www.defender2.net/forum/topic22153.html |
We have them on our website as do Mobile Centre and MUD ![]() http://www.farrowsclassics.co.uk/Carling-Switches----6-95.html 99p each |
It's just an additional block which allows you to easily unplug the switch in one go, rather than having to unplug each individual wire. The wires go into the block, and the block clips onto the back of the switch. |
