Home > In Car Electronics > How do I remove Carling switch connector?
WarPig
The +ve wire has come out of the Carling switch block for my heated windscreen. How do I remove the connector thats still inside the block please? Ive crimped a new one to go back in but I cant get the old one out. Tried pushing/pulling it with pliers etc....
Post #255160 1st Aug 2013 6:50am
from the other side slide a thin metal blade between the plastic & brass connector then pull from the other side Thumbs Up theres a tiny brass locate lug there Thumbs Up
Post #255163 1st Aug 2013 7:07am
GUM97
I haven't got these switch connectors on mine Shocked Shocked An engine to TDi for!
Post #255171 1st Aug 2013 7:28am
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
That'll be one of those relay type holders for a carling switch. From the other side you should be able to slide a thin blade screwdriver or something similar down the side of the connector to release the little clip that holds it in place then, at the same time pull it out from the back 2013 Aintree Green 110 Station Wagon SX
Post #255172 1st Aug 2013 7:34am
WarPig
Done it. Thanks guys Thumbs Up
The +ve wire was touching the other connectors which I think is the cause of some strange problems I encountered yesterday, posted here....
http://www.defender2.net/forum/topic22153.html
Post #255198 1st Aug 2013 9:18am
We have them on our website as do Mobile Centre and MUD Thumbs Up
http://www.farrowsclassics.co.uk/Carling-Switches----6-95.html 99p each
Post #255201 1st Aug 2013 9:23am
WarPig
It's just an additional block which allows you to easily unplug the switch in one go, rather than having to unplug each individual wire. The wires go into the block, and the block clips onto the back of the switch.
Post #255208 1st Aug 2013 9:43am
