Home > Puma (Tdci) > Britpart Electric Window Kit |
Smudger,
According to the diagram you only need a single relay marked up as R143. The coil protected by a 5 amp fuse link 15 and the contact a 60 amp fuse link 3. Don't know if you have the slot for the relay or fuses in your model but either way it shouldn't cost much. Hope this helps. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
31st Jul 2013 3:48pm |
Smudger Member Since: 26 Nov 2012 Location: Basingstoke Posts: 36 |
Thanks for the advice.
Smudger 08 110 Puma Station Wagon 65 Jaguar XF Sportbrake S 99 Elise 111S Honda XR250 42 Royal Enfield Flying Flea 43 Matchless G3L |
31st Jul 2013 7:15pm |
