![]() | Home > Puma (Tdci) > Britpart Electric Window Kit |
Smudger,
According to the diagram you only need a single relay marked up as R143. The coil protected by a 5 amp fuse link 15 and the contact a 60 amp fuse link 3. Don't know if you have the slot for the relay or fuses in your model but either way it shouldn't cost much. Hope this helps. ![]() Treat every day as if it is your last....one day you will be right!! |
Smudger Member Since: 26 Nov 2012 Location: Basingstoke Posts: 36 ![]() ![]() ![]() |
Thanks for the advice.
Smudger 08 110 Puma Station Wagon 65 Jaguar XF Sportbrake S 99 Elise 111S Honda XR250 42 Royal Enfield Flying Flea 43 Matchless G3L |
