![]() | Home > Maintenance & Modifications > bulkhead landy 110 |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I can't see any photos but bulkhead rust is a common failure.
You'll end up replacing or repairing the bulkhead at some point so factor that into your pricing. Maybe better to look around for one that doesn't have such far-advanced rust. It'll maybe buy you a few more years before remedial work is required. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
blackenedcrisp Member Since: 28 Feb 2010 Location: Southampton, UK Posts: 2 ![]() |
Sorry new to this site and can't seem to put any photos on.
Any Ideas[/img] |
If the holes are on the outside, far left and right corners (under the screen) you can buy a repair pannel for each. These you can weld on place, if you take your time and get it right once painted it will be hard to spot.
If they have gone here the chances are it has also rotted on the inside (opposite), here you need to take the dash off. If there are holes you can weld a small plate over it. HTH Boy |
