Home > Puma (Tdci) > Grinding noise
kjmeijer
Netherlands 2016 Defender 110 Other SW Galway Green
Grinding noise
When I got my 130 it still had about a year of factory warranty. From the start there was a grinding noise from the back of the car when I released the gas pedal at about 110-120 km/hr. The dealer put an other rear diff in but the problem was not solved so they put in a second rear diff. Still not solved and I got my third rear diff. The noise was still there and they changed the angle of the prop shaft. The noise was gone and to be sure that there would not be left a broken diff they put in a brand new rear diff, my fourth in about 3/4 of a year. Great service of the dealer!
There was no grinding for months but now I am starting to hear it again. Not as loud as in the beginning with the first diff but audible. Last friday I was at the dealer for a test drive with a mechanic and he also heard the sound. Next friday it is of to the dealer for a day of testing.....
They allready said that replacing the diff again is no solution so they will be looking for other things. Any ideas? 2021 Defender 110 D300 HSE
Post #254157 28th Jul 2013 6:17pm
K9F
You're not Caterham are you? Re-registerd under a pseudonym? Forum joke sorry......
Bow down If you go through life with your head in the sand....all people will see is an ar5e!!
Post #254199 28th Jul 2013 7:45pm
Caterham
Rolling with laughter
Shocked
my diffs have been fine.....best go check !
joking aside having had the diffs replaced I can only assume they were never the issue? reminds me of my dads disco 1. they were just about to replaced the third gearbox when mr LR (tech from factory turned up and told dealer that the noise was quite normal) - I presume it was cos the noise never got any worse in the c10 years my dad had it and never caused a problem Confused
I can't really help I'm afraid but what amazes me is when it comes to the transmission the defender is to my mind very simple yet seems to cause people no end of problems - I just can't understand it?
Post #254230 28th Jul 2013 8:42pm
kjmeijer
Probably you are right. The dealer said that in the first diff (where the grinding noise was very very loud) there where scrapings of metal so I think living with the grinding noise is not an option. 2021 Defender 110 D300 HSE
Post #254290 29th Jul 2013 6:45am
theorangebandit
Mine does this too ill have to check the diffs may just give the beast an under side service too
Post #254297 29th Jul 2013 7:44am
I think the first thing that needs changing is your dealer. Four diffs and problem not solved just does not sound right to me.
Post #254563 30th Jul 2013 8:52am
MartinK
Re: Grinding noise
kjmeijer wrote:
... they changed the angle of the prop shaft. The noise was gone and to be sure that there would not be left a broken diff they put in a brand new rear diff, my fourth in about 3/4 of a year. ...
Hmmm I wonder how they "changed the angle of the prop shaft". Maybe that's more related to the problem than the rear diff.
Supacat is IMHO correct:
If you were in the UK, I would suggest a trip to the gods of Land Rover transmission...Ashcroft... Thumbs Up
However, just a thought - other than the "change the angle of the propshaft" bit, could it be something completely unrelated to the diff? Does it do this in all gears or just 6th? Does it do the same at the same revs in a different gear? (i.e. is it rev related or speed related?). Is it the same if you freewheel? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #254579 30th Jul 2013 10:06am
kjmeijer
Next Friday there will be a specialist from LR Netherlands so I hope he can locate the problem.
At the moment the problem is only there (or audible) at higher speeds in 5th or 6th gear. With the first diff I did sometimes hear the noise in four at lower speeds but now it is only audible at 100 - 120 km/hr.
The sound turns up when I suddendly let the gas pedal go up and when I press it again I can hear it also, but not as loud. It is not possible to position the pedal in a way that you keep hearing the noise so it looks that it is something related to pressure differences on the diff (or something else). 2021 Defender 110 D300 HSE
Post #254859 31st Jul 2013 7:22am
Re: Grinding noise
I wondered that too. The only thing I came up with was that maybe they altered the 'phasing' of the two Hooke joints by dismantling the splined joint and reassembling in a different alignment. I wouldn't however have thought that either the shaft was incorrectly assembled beforehand, or that this would alter a "grinding" noise.
The noise/accelerator relationship does indeed sound like a diff characteristic. We do know from earlier posts from Ian Ashcroft that some LR diffs are shockingly badly set up, perhaps this has a bearing (no pun intended) on the problem.
If it was my 130 I'd be very tempted to go for one of the new Aschroft HD long-nose diffs.
Post #254876 31st Jul 2013 8:54am
kjmeijer
Well, the expert of LR Netherlands said that is was not the rear diff but the transfer-case. They have put sensors under the car to locate the source of the grinding and now it should be the transfer-case. The story is that the transfer-case had to adjust to the new rear diff and that is what is making te sound. Nothing to worry about, it should be quite normal. When the grinding sound becomes louder they will have to look at the transfer-case but for now it should be fine.
The first diff which was replaced was really broken but if it was neccessary to replace it again and again? Lots if questions but no satisfying answer from the dealer. 2021 Defender 110 D300 HSE
Post #256382 5th Aug 2013 12:21pm
Someone really is blowing smoke...if anything in the transfer case can self adjust then it's already loose/broken!
I think they are using an excuse they use on the auto boxed models where the software does adjust to various inputs over time and can be re-set as and when required. For a manual Defender this is not true. Go back and tell them you would like another lucky dip from the big book of excuses...
Post #257725 10th Aug 2013 1:00pm
