![]() | Home > Puma (Tdci) > ENGINE MANAGEMENT LIGHT |
The rusty coil in the middle of the fan is the viscous fan coupling. Can't think of any reason why spraying that with oil would result in an engine management light - it's an entirely mechanical device with no connection to anything else. Darren
bunnyman Member Since: 29 May 2013 Location: herts Posts: 124 ![]() ![]() ![]() |
thanks for that darren haven't done anything else does that mean a trip to land rover or just wait until something stops working ?
Could be a nuisance code like the P1103 EGR one that automatically resets after a few driving cycles. In the absence of a fault code reader and no limp mode I'd leave it a couple o' days. If you go through life with your head in the sand....all people will see is an ar5e!!
Thanks k9f
just had land rover do a diagnostic, came back with air mass meter fault ,eml light was on when picked up, it up went off on the way home, came back on today.is this air mass meter easy to change was quoted £174.00 looks like two screws if im looking at the right part? any help would be greatly appreciated thanks bunny.
Price a tad high....
http://www.defender2.net/forum/topic21286....maf+sensor http://www.defender2.net/forum/topic20750.html?highlight=maf Where to get one.... ![]() http://www.defender2.net/forum/topic17976.html?highlight=maf If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
many thanks again k9f
