Home > Maintenance & Modifications > Front Offside Indicator
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Whilst on the paper run this morning, went to indicate left and the indicator light on the panel was blinking rapidly, checked front offside bulb and it was not working, replaced bulb and the same thing happens, rapid blinking on panel plus the new bulb was not working, when indicating to go right everythings ok.Anyone know of a quick fix or is it a warranty job. Cogito ergo sum
Post #25303 27th Feb 2010 2:15pm
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Are you absolutely certain the new bulb is ok? A check for definate is to replace it with one in the other side, that you know works. If still not working, have a look at fuses next, if I were you. Mark
2011 110 XS DC
Stornoway Grey
Post #25305 27th Feb 2010 2:21pm
scatt
England 2008 Defender 110 Puma 2.4 DCPU Alpine White
I had a simular problem and took it to landrover, They ended up replacing the earth wire in the loom. about 3 feet! Big Cry but that was ont the h/side rear.
Post #25306 27th Feb 2010 3:02pm
Paul55
This gets better, have know checked all fuses, A ok, and changed the bulb over with one I knew was working, now none of the indicators work Big Cry , changed the bulbs around again and still no indicators working Banging Head , have know resigned myself to having some newcastle browns whilst watching the beautiful game, Rugby that is. I'm suspecting the indicator stalk maybe fooked, unless someone knows different.
Come on England Bow down Bow down Cogito ergo sum
Post #25307 27th Feb 2010 3:39pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
The indicator stalk comes as a complete unit, mine failed on the main /dip function
Post #25309 27th Feb 2010 4:48pm
MuddyMarky
??? Eh?? Sorry about that mate....didn't think that'd happen! Shame about the result too, for England Sad (Good on Italy though Smile ) Mark
2011 110 XS DC
Stornoway Grey
Post #25325 27th Feb 2010 7:51pm
Paul55
Odd thing is when I push the button to central lock it ,all the indicators work except for the one that was bu**gered int he first place, looks like a call to Hunters in the morning Big Cry Cogito ergo sum
Post #25359 28th Feb 2010 8:54am
Grockle
Paul,knowing you,have you taken the side light to bits instead Rolling Eyes pop round I'll have a look Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #25363 28th Feb 2010 9:17am
Paul55
You tart, where are you know Italy still or lovely cold blighty, Laughing Cogito ergo sum
Post #25364 28th Feb 2010 9:23am
K9F
Paul must be a bit early for you! Laughing He's hardly going to 'pop round' if he's sunning himself and gorging himself on tagliatelle in Italy now, is he? Couldn't resist sorry! Bad earth I reckon as the alarm function may have a separate one!
Cancel that!!!! See post below!
Thumbs Up Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #25371 28th Feb 2010 9:51am
Grockle
just got back ,I can still smell the hot engines and tyres from those Jags Twisted Evil 2.4 90 XS
Post #25372 28th Feb 2010 9:52am
K9F
Just a thought!
Just had a quick glance at the wiring diagrams, this may (or may not help) both the supplies for each front indicators and the associated earths is shared with the repeater indicator.
When you had your initial problem was the repeater still working? If it was a simple bulb failure the repeater should still operate.
The alarm supply is totally separate but feeds onto a common supply branch to all indicators and eventually uses the same supply path and earths as the indicator stalk.
In summation if they work with the alarm the fault must be before the common supply branch to the indicator stalk and it's supply.
If they all work on hazards this too will help reaffirm it and hopefully direct you to where the problem is! If not you've bought a duff bulb and it is confusing the issue. Start again with all known serviceable bulbs. Good luck! Thumbs Up
Hope this makes sense. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #25376 28th Feb 2010 10:04am
Paul55
Thanks for all the replies gents, called out Landrover assist this morning and problem was resolved in 15mins, apparently when it went into the dealers the other day for new headlamp rims they had inadvertantly loosened the wires at the back of the bulb unit, I know, I know should have checked all the connections Embarassed , lesson has been learnt. Grockle before you say anything at all, bo**ocks Rolling with laughter Cogito ergo sum
Post #25390 28th Feb 2010 11:52am
MuddyMarky
Rolling with laughter Rolling with laughter
Glad you're sorted Paul Thumbs Up Mark
2011 110 XS DC
Stornoway Grey
Post #25395 28th Feb 2010 12:40pm
Grockle
you can't help some people,first there was the roof rack I made followed by the rooftent and even the heavy duty off road camping trailer were either rejected or like the trailer left in a layby nr Monyash.
later this morning,....'hello is that the AA ?, it's me again Paul55 can you come and open the drivers door for me the handle is everso stiff,I'm stuck inside and my dinners nearly ready'...... 2.4 90 XS
Post #25400 28th Feb 2010 1:17pm
