![]() | Home > Puma (Tdci) > HARDTOP TO PICKUP |
Hi Josh,
Probably an hour the first time and less once you've done it a couple of times. Yes, a TD5 truck cab will fit - they're all the same. You'll also need a tailboard, which is slightly more complicated as your van body won't have the fittings for the hinges and latches. Not insurmountable though, as the parts are readily available. You'll need to drill some holes to mount them. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Easy nut and bolt job
![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
sib Member Since: 18 May 2007 Location: Baaath Posts: 144 ![]() |
Clinton from "Longranger" has a totally mint Keswick green truck cab top if you are interested if he hasn't put it on eBay yet...and another one coming in a week or so. Sib
Bath UK 1952 80 inch 1973 88 inch 2018 Morgan plus 4 narrow body |
