Home > Puma (Tdci) > Anti-Stall |
adiep Member Since: 18 Nov 2012 Location: Gibraltar Posts: 204 |
Does anyone know if the basic basic model of Puma without ABS and traction control has the anti-stall?
Yesterday got stuck in some sand, took my foot off the cluch expecting wheels to spin and it just stalled... Recently had a new clutch and wodering if i dont have antis-stall, or if the sand was too deep or is the mechanic broke somthing when replacing clutch... any ideas? |
21st Jul 2013 11:52am |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Remember anti stall only works when you first start up, and stays active until you touch the accelerator pedal.
If you didnt restart after getting stuck then anti stall wont work ... Guns and Landrovers .... anything else is irrelevant. |
21st Jul 2013 12:13pm |
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 |
Anti stall works in 1st and reverse gears in low box only. I believe it's fitted to all Tdci models, it's certainly fitted to our County spec USW and works exceptionally well in the Training mode we bought it for.
21st Jul 2013 12:39pm |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 |
Also here, no ABS nor traction control and anti-stall works pretty well on my 110 HCPU Peter,
Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
21st Jul 2013 1:08pm |
Low box... ah, thanks guys
21st Jul 2013 1:14pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Anti stall works in all gears in both hi and lo ratios, but in high ratio and high gears depending on the engine load can induce a stall. Idle Jack works in lo ratio 1st and reverse only and is designed to overcome the enormous amount of engine braking which could induce a slide when descending/ascending a steep slope. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
21st Jul 2013 1:26pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20413 |
What he said above. $W33T $0U7H3RN $UG4R
21st Jul 2013 2:09pm |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 |
What's idle jack?!
21st Jul 2013 2:58pm |
Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
21st Jul 2013 3:00pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
Idle jack is when the engine tickover is increased to around 1200rpm.
21st Jul 2013 9:09pm |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
On YouTube there are videos of people getting out of their Puma's walking alongside while it runs along on anti-stall, then getting back in. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
21st Jul 2013 9:34pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Thre,s another one on you tube of a Defender towing an artic while the "driver" walks along side. 2005 Td5 90 XS
Steve |
21st Jul 2013 9:38pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8044 |
i can confirm as above, on a TDCi anti stall works in all gears; high and low. obviously the lower gear the better it is and the more time the engine ECU will have to react to make the anti stall effective.
the sand could well of been creating sufficient drag to make even TDCi anti stall struggle to cope Touching the accelerator does not turn it off on the TDCi but it does on the Td5. Idle jack works in low 1st and rev and as above increases engine revs to around 1100rpm. this is to increase the vehicle speed and not provide too much engine braking when using low 1st and rev for descents as too much engine braking will increase the risk of losing traction. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
22nd Jul 2013 6:17am |
Sorry but I think you will find that anti stall works in 1st & reverse in Low box only. The idle speed in these gears is also increased. It most certainly does not work in all other gears.
22nd Jul 2013 9:47am |
