Home > Puma (Tdci) > Dash warnings. |
It could be a sensor, but it could also be chaffed wiring, which a few Puma owners have reported, or even a wheel bearing.
Chaffed wiring is the only one that would be visible, but even that might need a diag. check to determine which wheel to look at. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
10th Jul 2013 11:43am |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3373 |
Have a look on this thread, http://www.defender2.net/forum/topic21616.html
The unit reads / clears fault codes as well as streaming live engine data to your phone / tablet All for under £15 |
10th Jul 2013 1:30pm |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 |
Red Dot,
I have the same issue and believe it to be a sensor as it started gradually coming on after 20 minutes of driving, and now it comes on every time. If you want a short term solution, get yourself going at a reasonable pace, put the clutch in and let it freewheel while you switch the engine off and start it up again and let the clutch out. Lights out Also some people have had earthing trouble with one earth on the bulkhead behind the water expansion tank and also on the inside of the chassis rail next to the battery box. Worth a check there and also whether the terminals are tight. Cheers, William William |
10th Jul 2013 1:32pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
Just tried a hard reset but still on.... will give all suggestions a try. I mashed a cable in a rut and a quick fix was done four years ago so i will check the repair hasnt come undone. It is known as the 3 Amigos i believe. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
10th Jul 2013 1:58pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
I had this problem the lights were intermittent , it turned out to be a chaffed wire, don't know which one I took advantage of my 1 year land rover warranty
10th Jul 2013 3:09pm |
vogue se Member Since: 24 Jan 2008 Location: Bocholt Posts: 111 |
With my 2008 Defender, the dealer had to replace the wiring of the back axle. That is a common failure.
10th Jul 2013 5:27pm |
RD.....
Hope these help..... Page 3 of the first link. Resistance figures for each sensor should be about 1kohm http://www.defender2.net/forum/topic2394.html?highlight=abs http://defender2.net/forum/topic20879.html?highlight=gap If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th Jul 2013 2:04am |
