Home > Maintenance & Modifications > Help needed - 110DC 2nd row seat fitting |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
I would say that the position of the seat brackets would be identical . after all defender is a base platform. I removed the rear brackets for my rear seats was only four boolts so four holes to drill
8th Jul 2013 11:22am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
You'll need to source / fabricate reinforcing brackets for underside.
8th Jul 2013 11:24am |
Welly911 Member Since: 14 Oct 2012 Location: Cheshire Posts: 70 |
Thanks for the speedy replies. I've got a good fabricator that can make some reinforcement plates. Was wondering if the Dual cab had the same plinth attachment that secures to the cabin floor like the Station Wagon. Or do the receiving catches on the bottom of the seats remain unused in the DC. Thanks again. Mike
P.S bloody heavy aren't they?!? Probably justify a ECU Re-map now.... |
8th Jul 2013 12:07pm |
Yes, they are heavy !!!
The receiving catches are identical, did you get those with the seats ? |
8th Jul 2013 12:15pm |
have the receiving attachments for the bulkhead (similar to TD5) but wonder if I require a base plate to fit onto the floor that has the single and double seat plug into?
Go Beyond - i've loved your projects to date.... might have to get some of the locals to attempt some on my Defender out here in Dubai.... |
8th Jul 2013 12:32pm |
