Home > Maintenance & Modifications > Help needed - 110DC 2nd row seat fitting
Welly911
Afternoon all, i'm a 110DC TD5 owner trying to improve the ride of my Defender. I've managed to get my hands on a full set of TDCI/Puma seats and am looking for advice/direction on how to successfully install the 2nd row of seats. I've studied the YouTube instruction and all the other posts so far.... But all the have been Station Wagons and no Dual Cabs.
Please help
Cheers Mike
Post #249943 8th Jul 2013 11:15am
theorangebandit
I would say that the position of the seat brackets would be identical . after all defender is a base platform. I removed the rear brackets for my rear seats was only four boolts so four holes to drill
Post #249944 8th Jul 2013 11:22am
You'll need to source / fabricate reinforcing brackets for underside.
Post #249945 8th Jul 2013 11:24am
Welly911
Thanks for the speedy replies. I've got a good fabricator that can make some reinforcement plates. Was wondering if the Dual cab had the same plinth attachment that secures to the cabin floor like the Station Wagon. Or do the receiving catches on the bottom of the seats remain unused in the DC. Thanks again. Mike
P.S bloody heavy aren't they?!? Probably justify a ECU Re-map now....
Post #249950 8th Jul 2013 12:07pm
Yes, they are heavy !!!
The receiving catches are identical, did you get those with the seats ?
Post #249951 8th Jul 2013 12:15pm
Welly911
have the receiving attachments for the bulkhead (similar to TD5) but wonder if I require a base plate to fit onto the floor that has the single and double seat plug into?
Go Beyond - i've loved your projects to date.... might have to get some of the locals to attempt some on my Defender out here in Dubai....
Post #249956 8th Jul 2013 12:32pm
