![]() | Home > Maintenance & Modifications > Oil Grades |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
GL-5 is normaly only used in diffs but can be used in a gearbox if the vehicle specifies it.If you use it in a gearbox that requires GL-4 you will eat up your syncros with the additive that is in GL-5.Ford normaly uses 75W90. Puma 110 SW
90 V8 SOFT TOP |
Gearbox oil is Castrol BOT328 (BOT130 is superseded) and is a (fill for life =200.000km) synthetic 80-W90 GL4 and GL5 gearbox oil Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
Thanks for that information, do you buy your castrol online? |
it's quite difficult to buy on line............ I bought my BOT328 directly from my LR dealer (at a good discounted price ![]() ![]() IID Pro MV License |
